So I have been posting a lot about a vibration I was convinced was suspension or drivetrain. I'm coming to the conclusion that I think its either transmission or engine and I need your help.
So here is the data
HG and top end rebuilt at 220k, now at 298k
Injectors were flowed and balanced at that time, they were rebuilt with new seal as needed by RC engineering
since then a single injector was replaced due to damage from shorting a lead against the intake. OE new replacement
fuel filter (engine) is less than 60k old.
PVC valve was replaced about 50k ago
the little "fuel filter" (the one on the top of the intake) was replaced then as well.
symptoms
A little rough idle, not too bad but it "farts" a little at the exhaust pipe, not a miss, but a little rough
"grrrrrs" on acceleration, sometimes worse than others. Normally the 1FZ "mooos". Feels like a missing injector but much less severe.
Associated with a vibration felt inside.
Power is a little low on low rpm but doesn't seem overall down on power
Hot exhaust
Doesn't show any problems revving out of gear, there is a slight "warble" from 1800-2600 if you hold the throttle there out of gear.
Smells rich and hot.
What I've checked so far
I just replaced the spark plugs (image below) and they looked fine on all cylinders, no odd patterns
Checked the MAF for Resistance and voltage per FSM and its in spec.
Checked the upstream and downstream O2 for resistance per FSM and in spec.
Been keeping at eye on both the short term and long term fuel trims. (images below)
Temps seem to be in line with reality (based on ECU scan) so I don't suspect its a bad sensor there.
My theory is that its its running lean or rich for whatever reason but I can't see any strong symptoms of this.
Not burning coolant, burns a small amount of oil.
I will try and get some audio of the symptoms.
Where can I look?
So here is the data
symptoms
Hot exhaust
Where can I look?
