Running rich
Sandy Utah area
I've got a rich smell and I'm suddenly using a lot more fuel. No codes, whats a good first place to look?
97
How is it running? Do you see black smoke out the tape pipe? How long has this been going on? Have you actually calculated mpg for verification? Inspect for leaks. Check for stored dtc’s. Pull and inspect spark plugs.
I just got a P0172 code yesterday. Running too rich. Smells a little too. O2 sensors were replaced less than 2000 miles ago.
I'll take it to the mechanic and report back. Could be a number of problems.
97
Probably leaking fuel or fumes. If your running rich the OBD would code up.
^this
I'd start with O2 sensors.
Using the OBD II reader and app im showing good voltage on the upstream sensor and downstream sensor. Next step is manual check. They aren't original and look in good shape. Is there a point checking the MAF or would that throw a code if that wasn't reading right?
Running not great. sometimes its fine, sometimes it vibrates at certain rpms. it has power but its not smooth. I've been chasing this vibe for a while and I had thought it was chassis or driveline (I am replacing some suspension parts that are bad). The intermittent nature of the problem leads me to look at the engine. I need to pull the plugs and check them out. In fact I should probably just replace them while Im at it, they were replaced about 75k ago.
Thats the bit I can't square. It doesn't smell like gas, it smells rich like the cats aren't functioning. I need to check the downstream O2 sensor to see if thats actually the case.
the only way the engine will run rich AND not throw a code is if the O2 sensors are bad. No getting around this.
It just that it's the only possibility for the symptoms you describe. Driving around running rich will wash the bore and be as damaging as running lean.
If it is running seriously rivh you should be able to smell gasoline really strong on your dip stick.
