Rubbing?-
Santa Monica, CA
Website
www.elirubelphotography.com
So I noticed that both my rear tires spin freely as they should up until a specific point in their rotation....I figured that my rims were rubbing, but then after taking a closer look, remembered that the rims bolt down to the actual outer casing, so there is no way they are the problem....The brake lines have not been run yet, so I dont think that could be the issue...
The only thing that I could think of is that maybe the brakes (two little things inside the drums) are slightly applied or something....But then wouldnt it effect them for the full rotation? I remeber that the guys at SOR tech, said that once I had fluid in them I am supposed to click them in a certain amount until they cant spin and then back them off 3 (if im remembering right) clicks...
There isnt a terrible amount of hold when going through the ruff spot, but I dont want to be doing any damage... when rolling it on a flat surface by hand, it rolls easy untill it hits the one spot, and then I really have to start pushing...
ANY IDEAS?????
If its been sitting for awhile, its probably just rust in the drums. If it is just a slight drag I wouldn't worry about it.
How about a bent axle? Does it look like your drums wobble as they turn?
Probably just need to seat the brake linings a few times, I would not worry about it. You'll probably want to adjust the brake linings again after you have used them a couple of good times anyway.
I've been following your build thread and since you havent used your brakes yet I wouldn't worry. You probably have one shoe pushed out a bit to where it dragging. Wait until you hook up your lines and adjust the wheel cylinders than take on a couple road tests in the neighborhood. You'll have to bleed and make adjustments as you start driving it. With a whole new brake system its to be expected. If it bothers you that much take the drums back off adjust the wheel cylinders all the way in so that they don't drag and you should be good. I don't remember did you have your drums turned down or did you buy new ones? If you had them turned its possible the shop had a bad cut on the drums and they aren't running true causing the contact patch to drag in a certain spot.
