rth hub on spindle force?
Rio Rancho, NM
Is there a trick to getting hub assembly on spindle shoulder? Seems like it's not wanting to go on any further or off and still have quite a gap. I'm afraid to damage the seal if I hit it it with hammer or slam it on too hard. Am I just being to cautious?
Used plenty of grease and inner bearing is seated properly in its spot.
I had trouble with mine and it was 2 different problems (one on each side):
1) on the driver side I used wayyyy to much grease on the spindle and it was actually enough to stop the hub from sliding all the way back. I wiped most of it off and left a thin film and it worked fine.
2) I damaged the seal driving it in. Upon careful inspection I found the little garter spring was actually out (not tucked away as it should be) which was getting between the spindle and the hub stopping it from sliding all the way. It was hard to figure out until I stared real closely at the back of the hub.
Hope this helps
Thanks, I may have too much grease?
It isn't sliding back off though. I gave up for the evening and watched several videos mine isn't that far off and may be fine just seems to me that there was alot more threads showing on spindle when I removed thrust washer and nuts during tear down and now the outer bearing is right there on edge where I need to start the nut. I didn't try the nut because didn't look right maybe it will cinch it in...
Races are seated and seal was punched in with proper driver, hard to imagine it's damaged from sliding in and putting on spindle, the style of seal is closed unlike the inner seal with exposed spring/rubber.
Thanks for ideas, l got one on but the other not yet.
I'm not positive but I beleive if the bigger bearing inside was on backwards the seal would not go in...possible?
That is what I was thinking too just not sure if it could be.
I had to torque my WB to 65+ ft lb while rotating before the bearings would "seat" on the spindle. I could feel it increase in torque, but I could visually see I had about 1/4" more that I needed to go on based on the length of the spindle protruding from the center of the hub.
I felt it finally seat, then I adjusted torque accordingly and things are good!
I follow the install posted by @Tools R Us which also is very close to the procedure for a Chevrolet K10 69-87.
