RTH: front elocker diff pooched
sandcruiser
....back in the saddle again....
Pacific Grove, CA
I'm trying to help Nicolas get back on his way around the world, you can read about his journey
https://forum.ih8mud.com/80-series-tech/329265-aroubd-world-80-a.html
https://forum.ih8mud.com/80-series-tech/334914-transworld-expedition-80-houston-needs-help.html
Trans World Expedition
He had a collision with a mountain in Honduras, which led to replacing the axle housing and the short-side axle shaft (among other things).
He made it to Costa Rica where I took his rig for a test drive and we noticed that the front drive shaft turns when the vehicle is stationary if you are in D or R.
This is a '96 w/ elockers and a VC in the tcase.
So we tore down the front axle, hoping to find a stripped drive plate. No such luck. The drive plates and the axle shafts (both inner and outer splines) look to be perfect.
So we pulled the 3rd. We locked the locker first, then pulled the heavy beast out to see what's up. When locked, it works like it should... you turn the pinion flange and the side gears move.
So we started fiddling with the diff some more and learned the following:
If the sleeve is in (locked) it appears to engage the LH side gear (short side) and spin both sides.
If the sleeve is out (unlocked) it still pushes hard on the LH side gear, but if I wedge the tip of a screwdriver into the RH side gear, we can hold it steady. [ie: normal diff operation]
But! If I try to hold the LH side gear and spin the pinion, that side gear can shift slightly in/out and there is spot where I can hold the LH side gear and also the RH side gear, but the Ring will still rotate when the pinion flange is turned.
In other words: I can hold both LH and RH side gears yet still rotate the ring gear. That's not good. We haven't torn down the diff carrier yet to see the spider/spider gears, but I think that is where the problem must be located.
I think that if we pull the carrier, we'll find that one of the 4 pinion gears in the carrier is busted, or the spider itself has snapped, or, the big long-shot, the thrust washer on the LH side gear has disintegrated so that side gear now has too much play and can get away from the spider gears.
Another observation: the LH side gear (short shaft side) if pushed inward by the axle, seems to engage the pinions and the whole diff operates just fine. But if there is no inward pressure... then the side gear gets pushed slightly (1/8"?) away from the pinions and disengages.
Any guesses from the informed members of Mud are very welcome. Today we hope to find out if the spiders can be purchased separately from the 3rd. And/or the LH side gear.
If so, we'll tear down the carrier to see if we are right that the spider is broken or the LH side gear lost teeth.
If not, we'll try to source a 3rd either here or in Panama and get Nicolas back on the road in 2wd until we get the new 3rd.
All comments are very welcome!
Hard to imagine what the problem could be, but here what the inside of the carrier should look like:
thanks for the replies
the short side shaft isn't stripped
the side gears each have good splines as well.
anyone have a depth measurement on the splines? I didn't measure, but I'm 99% sure that they are fine.
wait-- 100% that the problem is NOT the short-side shaft because I can replicate the problem with the shaft detached entirely.
So we need to look more at the side gear, and probably open the diff to look a the spider.
keep the suggestions coming!
yikes!
we can buy parts here.... but they add up fast!
41371-35020 spider x1. about $90
41331-35040 side gear RH x1 $300 (holy cow!)
41331-60040 side gear LH x1 $100
41341-30020 pinion gear x4 @ $60
41351-30060 pinion thrust washer (x4 @ $3)
so if we have to do the whole shootin match, it is gonna cost almost $700. Time to look for a used 3rd!! (and to look at other toyota markets for parts)
a new third, by the way, here in CR will run a neat $1,646. I do believe that does NOT include the motor for the elocker. Ouch.
ouch. His truck is going to pratically rebuilt by time he gets home at the rate he's going.
Wish him the the best of luck. And thank you for helping a fellow cruiser out.
I can get a 3rd member in Dallas for $350 - how much to ship to CR? I dunno...
1998
Differential Assembly
Toyota 4Runner
LIMITED,ATOD,RWD
A087341
$350
Import Salvage Parts & Autos USA-TX()
Request_Quote 877-843-0420 / 972-843-0421
I know it says 1998 4Runner, but it cross references to 1996 Front Elocker 3rd in the interchange manuals.
1998
Toyota 4Runner
LIMITED,ATOD,RWD
A087341
$350
I wouldn't trust this without getting some sort of Toyota corroboration.
ok, so the latest news is that we need part number 41039-34060
that's a whole kit with 2 side gears and 4 pinion gears. And explains why they want nearly $400 for it. Ouch.
If he had broken this just a few years ago it would have been $100 in parts.
So we are looking at options, but the part # that we need is in the country, so I have a feeling he'll take that route. But hard to guess at this point.
I know that this forum has a million "cDan is a great guy" posts, but I've got to add that he just spent 20 minutes on the phone with me, knowing full well that I was unlikely to buy anything at all from him at this time, just to make sure we got the right part number.
That is awfully good-natured of him to do and I sure do appreciate the effort on his part.
I'll post some pics later, first a #6 or two and clean up the tools.
carnage:
you can see that there is still a liiiiiittle bit of inner spline left on the side gear, which explains why if I push in on the axle, it can engage.
I did the EXACT same damage in my 87 Suzuki Samurai (running a lockright locker)... I slapped in 2 used side gears and all was well!
Hopefully you can get that Cruiser back on the road soon! :)
1998
Toyota 4Runner
LIMITED,ATOD,RWD
A087341
$350
While a 4.10 Low Pinion E-Locker out of the rear of a 4Runner/Tacoma etc. will bolt into the 80 series front axle the tie rod and the low pinion third will be occupying the same space.
how does one do this much damage in such a short time.
Good luck with the repair.
I've been following his blog and it sounded like an aftermarket part failed in the steering and caused him to lose control on a rough dirt road at speed. From the crash picture he posted, the right front tire probably smacked the hillside at a bizzare angle.
Next, a makeshift trail repair was made and he had to drive on it to get to a real town. I'm glad he is OK and that it sounds like the truck will make a recovery soon.
Go Nicholas!
