RTH front axle bearings
Bay Area
The 80 has 132k and the previous owner had repacked the axles around 100k and seems to have kept good maintenance upkeep. A week ago- i experienced some grrrrr-ing at hwy speeds and have on hand a full rebuild kit from CDAN.
I just pulled apart the front axle to find both 54mm nuts loose as can be. (so loose that i could remove both with twist by finger!).
Inside the spindle- there was still some red grease with some black mixing.(definitely not dry). The outer bearings after cleanup are indeed the Koyo oem ones and seem to be in great shape. No grinding or even marks on the rollers. The outer race has one circle of slight visual scoring (likely where the loose bearing roller was riding briefly). I ran my fingernail over the race and the visual score cant be felt. I also compared the movement of the bearing to a brand new one and they have about the same play.
My question is----should i just repack everything-change the seals and reuse these bearings/races given that the 54mm nut preload was SOOOO far off-----or have the bearings likely been damaged in a way not visible?
There was so much play in the birf/inner axle that i just started to get some inner seal blowby and diff fluid in the knuckle. Doing the Landtank test with the wheel up in the air--12/6 position had about 1cm of play prior to tearing into the axle.
I had pretty much the exact same thing happen to my Hilux - loose 54mm nut. Noticed and sorted immediately.
Like you, I already had the kit - so I changed everything, including the seals.
I then cleaned and bagged the old bearings and popped them into one of thre rear cubby holes for emergency use.
Never did have to use them, just your normal maintenance routines carried out thereafter.
SO - Do what I did! Because if those old bearing do fail on you - and they might - you will damage the new seals getting them out. And then have to buy new............
Im also not exactly sure the grrrrr-ing was 100% coming from the birfs/knuckle.
2 weeks ago- after a run- i got a plugged breather valve--which sucked birf moly into the axle and then overpressuring the axle--blew the front pinion seal.(to also be replaced in this job) After draining the goop-and being a 1qt low on gear oil i figured there might be some DIFF bearing issues as well. NO real chips in the magnet/diff drain plug..........just gritty shavings.
Im guessing fully redoing the rebuild with new bearings/seals/races would eliminate future guesses as to any POST rebuild noises that may arise so i know its not coming from the birfs.
many thanks for replys.:beer:
There is a locking tab washer that is supposed to be between those nuts. The ends bend over. I don't see it mentioned... was it missing?
In my rebuild last month, I found that on the driver side, both tabs were locked on the outboard lock nut :doh:. IOW, might as well have had no locking washer...
