The other question about this opening is whether the plug is tapered, by visual inspection of the new and old plug I doesn't appear. I have heard mention though that some believe it is a pipe thread.
I know this is an old thread, but I came across it and wanted to provide some information on the correct thread for our blocks drain plug. The plugs on our engines, and steering knuckles are NOT American NTP pipe, they are in fact British standard Whitworth. Whitworth pipe threads come in 2 different styles, and are NOT interchangeable with American pipe threads. Both the 1/4 and 3/8 inch Whitworth plugs have 19 threads per inch. Both the 1/4 and 3/8 inch NPT plugs have 18 threads pre inch, so you can see there both close in thread count. Even though an American pipe plug will start in the hole, and you may get a turn or two on it, don't do it, It'll damage the threads in the block or knuckle.
British Standard Pipe Parallel thread (
BSPP) straight Parallel threads.
British Standard Pipe Taper thread (
BSPT) whose diameter increases or decreases along the length of the thread.
If you can't find Withworth pipe plugs from your local vendor you can order them from
McMaster-Carr
BSPT
BSPP
- For Use With: Air, Water
- Specifications Met: ISO 7.1, ISO 228
Pipe
Size Material Plug
Construction Hex
Size, mm Max. Pressure Gasket
Material Each
BSPT
1/8 Nickel-Plated Brass Solid 5 2,900 psi @ 72° F __
4860K131 $1.89
1/4 Nickel-Plated Brass Solid 6 2,100 psi @ 72° F __
4860K132 2.92
3/8 Nickel-Plated Brass Solid 8 1,450 psi @ 72° F __
4860K133 3.26
1/2 Nickel-Plated Brass Solid 10 1,450 psi @ 72° F __
4860K134 6.09
3/4 Brass Solid 12 1,750 psi @ 72° F __
4860K135 16.91
BSPP
1/8 Nickel-Plated Brass Solid 5 2,900 psi @ 72° F Rubber
4860K125 3.74
1/4 Nickel-Plated Brass Solid 6 2,100 psi @ 72° F Rubber
4860K126 5.11
3/8 Nickel-Plated Brass Solid 8 1,450 psi @ 72° F Rubber
4860K127 5.76
1/2 Nickel-Plated Brass Solid 10 1,450 psi @ 72° F Rubber
4860K128 9.77
Plugs with External Square Drive Style
Pipe
Size Material Plug
Construction Max. Pressure Each
BSPT
1/8 Nickel-Plated Brass Hollow 1,000 psi @ 72° F
4860K315 $8.40
1/4 Nickel-Plated Brass Hollow 1,000 psi @ 72° F
4860K316 13.21
3/8 Nickel-Plated Brass Hollow 1,000 psi @ 72° F
4860K317 14.60
1/2 Nickel-Plated Brass Hollow 1,000 psi @ 72° F
4860K318 15.75
3/4 Nickel-Plated Brass Hollow 1,000 psi @ 72° F
4860K319 20.07
