rounded head on bolt
hey, i went to change the oil in my gearbox and transfer case today, but the head on the bolt where u fill it up, is rounded :(
any tips on how i could get it out??
Thanks
Might try pounding a smaller 6 point socket onto the bolt head. Get a new bolt and washer from your dealer or some place.
You mean the ones that have a big flat head that's thinner than it ought to be? If so, I've had some luck drivina 15/16" 12 pt socket onto the bolt, putting on a breakerbar, and tapping the bar handle until the bolt breaks it's torque. A little heat at the propane bottle level won't hurt and might help.
Same process for the littler bolt but I always find those pretty easy to turn - try visegrips.
Go with the allen head ones... saves alot of frusteration... ;)
Another option (try this after the above mentioned ideas don't work)...
is to weld a big nut or piece of bar-stock (so it forms a mini-wrench handle with the filler plug) to the rounded filler plug. Either use your favorite adjustable cresent-wrench or slide a piece of pipe over the bar stock, and 'Giver!
I had this same issue when I bought my rig thanks to the PO... so with a bit of filing with a file, squared off the bolt head into a rectangle/square to get much more purchase area, hooked up an adjustable wrench with a 2' breaker bar and it came free easy. I found this the easiest fix and it uses general home shop tools
BTW, now I use those 6 point hex heads from SOR that 'cruiseroutfit' posted on my t-case, trans, diffs, etc.
this only works once and a while but you may want to try it if you don't have a welder. zip cut a slot in the head of the bolt and use a big screw driver. You can use a wrench at the same time to try and break it. You can also zip cut the sides of the bolt to get a good grip with a cresent wrench. If all fails weld a nut on.
HawkDriver said:
Has no one mentioned using a pipe wrench on the round part of the plug? I hate boogered nuts and bolts and plugs. :mad:
I tired that on mine and no go. my neighbor had a pipe wrench that was like 3 feet long and it would just not bite. BUT, the moment I filed down the rounded and buggered edges into a rectangle with long sides, it came free easy. so much easier getting bite on 2 long flat sides than a partially rounded head, even if you are using a big ass tool.
