Rough running under load
Metro NY
Excuse the newbie ish question... I have a 60 and a 40 both with 2f engines and have only now for the first time encountered this issue. I've been driving a 2F for over 20 years....
In the 40, under load, most noticeable at lower RPMs and when starting from a stop, the engine bucks and hesitates and can only be kept moving by feathering the clutch and adding throttle.
Barring any other input I'm going to do a basic tune up: change the fuel filter, cap and rotor, change the plugs & wires, and adjust the timing.
I might try the timing first, any input would be appreciated.
Mark
Just do a basic tuneup without timing and see where that leaves you. I wouldn’t be afraid of checking timing but it’s not something that just changes.
Try pulling the choke when it's bucking. If choking it makes it any better, thegn the problem is a too lean mixture.
Not sure if this applies, but it’s good info regardless
Matt, If it is sputtering and stalling under light loads, but will run with the throttle floored, then it is in the carb. If it will idle and run at low throttle, but hits a wall above a certain load, then it is starving for fuel from the tank.
You can try removing the bowl drain plugs on the front of the carb and shooting some carb cleaner in there. Also try removing the fuel inlet line and spraying in there. Hose it down because you want to wash the debris out through the drain plugs. If that won't cure it, then the carb will have to come apart, BUT you will also need to address the root cause of the problem. Clean or replace the steel lines and tank, replace all rubber hoses, change fuel filter, disassemble and clean pump. Carbs don't generate dirt, they just collect it.
Is there a diagram in the FSM showing me which are the drain plugs?
I'll take a look later but I thought maybe someone here had a picture right away...
I do have the same problem,but only when I am backing up from the shed and motor is not warm enough....After like 5 minutes warming up it is OK...sometimes another 5 min during the ride it is bucking and hesitates,but after that is fine -no problems under load...
Mark, hex bolts on window side. Access to the jets also.
Hit the carb with some carb cleaner today with the drain plugs removed, found a broken vac hose from the carb to the distributor, replaced that... found open port on the distributor, and on the carb, plugged those. Fired it up and it ran as good as it ever has...really well.
Parked it for a while then took it out for a victory lap later and it ran like garbage again. Tomorrow I'll be a little more efficient in flushing out the carb, replacing the fuel filter and maybe replacing the rubber fuel lines.
To be continued....
Thanks Nick... Hey, are we going to see you at CMCC (the 20th annual) in July?
4 local auto parts store and none in stock... Amazon to the rescue.
Replaced the fuel filter, replaced the rubber lines to the fuel pump and from the hardline to the fuel filter, with the carb in place I pulled off the feed and return and the 2 drain plugs and sprayed the crap out of it ... put it all back together and it ran great until the second time I started it up and then it ran rough again... first running great was 30 minutes second running poorly was another 30 minutes.
Clear type fuel filter? See any trash in it?
I can look at the new filter tomorrow but the tank was new OEM just a couple of years ago so it shouldn't be dropping smoo yet.
I will be checking the cap/rotor tomorrow.
I have a known good spare carb AND distributor if push comes to shove.
Changed out the plugs, wires, cap and rotor today (w/all OEM parts). Pics of the crusty removed bits linked below.
First test drive yielded good running. I'll give it another test run in a little while.
Spark plug diagnosis?
