- Thread starter
- #21
yep just the hub to fender hight measurement for the front and rear if you don't mind. Also do you haul much weight around in the rear? What did you do about the rear drive shaft angles?
They are about 24 3/4 inches in the front and 25 3/4 inches in the rear. The rear is unloaded for the most part. I have maybe 30 lbs of gear in the back, no third row seat installed and my interior is line-x. So some subtracting and some major adding as far as weight. Last time I took my rig to the scales I think it tipped at 5640, that was without the winch. So I hope that helps. I will run her by the scale tomorrow if you would like and give you the numbers (I take it you are debating heavy or medium rear springs?)
Matthew
