rotor replacement
Central NC
everything flush, but no access to place ring clip?
Metric 8 x 1.25 bolt threaded into the end. Yep. Very common size on our trucks... you can probably find one to use easily in the engine bay.
Pull hub, pull bolts to rotor, smack edge rotor with rubber mallet disc will fall right off
You guys rock...such an easy fix. I was sweatin' it out, thinking I was going to have to tear all that back apart.
