- Thread starter
- #81
1
Turbo
Although some people do it, it is always best to add some type of cooling system to the turbo and the air it is moving around this is usually done in one of three ways.
1. Using the engines coolant---doesn't require a lot of space, but it adds stress to your cooling system and additional leaking points.
2. Separate coolant system with small radiator for the turbo or also known as air to water system. This system can help cool the air and the turbo but can take up a lot of space. It also may require electrical connections to run pumps and fans.
3. Air to air system using an inter-cooler that helps reduce the temps of the air going into the engine thus helping to reduce the temps coming out of the engine and into the turbo.
These engines are great on the flats, but start climbing hills and they start to work hard. If your turbo doesn't have an adequate cooling system your egr temps will rise quickly. Keep them high too long and you risk turbo failure. If the turbo fails badly you risk engine failure. Rule of thumb is to keep the egr temps below 1200F or 648C. And the further you can keep the egr temps from those numbers the longer the turbo is likely to last.
Hey Broth, what shop did you use for the exhaust work? My 74 is in need of new, bigger pipes and a muffler. Thanks
Sounds like the easiest and cleanest way to do this is to keep what I have in place. Do you think I need to keep the extra coolers attached to the cooling and oil systems?
Does EVERY 7x glove box door have a dent in it?![]()
Dan, How do you know those aren't just "character" markings? Kinda like wrinkles on an old guy.Does EVERY 7x glove box door have a dent in it?![]()
