- Joined
- Aug 11, 2013
- Threads
- 11
- Messages
- 129
So the next couple of upgrades to my LX470 are going to be a roof rack and a rear bumper. I have some design and engineering experience so I am looking to build the easier one (hopefully).....a roof rack. I have a few yakima accessories so my plan is to mount yakima bars onto the stock mounting locations. To the bars, I am mounting an extrusion frame so its easy to add all kinds of accessories. Here is my first cut at this design.
There are two brackets. The first(black) attaches to the stock mounting holes. Since I have not removed the current roofrack, I have not measured them so that bracket does not have mounting holes yet. Does anyone have these dimensions. I have searched the forum but I have heard they can be different between 100 and LX. The second bracket(Blue) attaches to the yakima bar by using yakima shear blocks (not pictured in cad).
Here is the similar real view. Used cardboard to make a mockup
Here is a view from above.
Both these parts could be made by using getting the flat pattern lasercut and using press brake. Also planning on welding the flanges to increase stiffness but that might not be necessary.
Extrusion is made by 80/20...part number 1020 (1"x2") and uses 1/4"-20 hardware. Yakima shear mount and brackets will use 3/8" hardware.
Currently I bought 58" yakima bars and 4 extrusions (2x 97" and 2x 72" long). They are way too long but give me the flexibility to go smaller. The smallest is probably 48"x84" so I can use the rack to get 4x8 sheets of material.
I have not figured out what to do between the bars and extrusions. There are multiple options I am considering but will probably use 2"x2" steel grid. I may just use just 1/4" baltic birch plywood with notches cut out.
