My wife and I have recumbent bikes that require a large footprint and the Home Depot trips. I am not planning on a tent, but I do plan on heavily using it for lumber.
To the roof, I used a 3/8" plastic wire loom and run that up the C channel on the passenger side front windshield. The wire loom splits open and the rear lights run along an interior grid to the back. I ended up notching a small spot in the plastic at the bottom of the windshield to feed the wire loom into the engine bay easier (the hood seemed to pinch it).Where did you run your power wire?
So you ran your power down the side of the windshield, I like it.
I'm not in Denver, I have a front runner and it is a little taller to just barely fit a table under the rack, since I have a RTT on top. Didn't know if that matters to you on the future. But even with that, it still is only has an inch of space to the satellite antenna in the back. Plus the accessory list of things you can bolt onto it is incomparable.I visited Slee this week and spoke with Ben about roof racks, I like the idea of aluminum racks, less weight, corrosion resistance, etc. As discussed in this thread, options include the Front Runner Slimline II, Prinsu, Rhino Rack.
I agree with many of Markuson's comments in this thread, Low Profile Roof Rack Options? The Front Runner looks to be a very high quality rack, with many accessories available, but appears to sit very high above the roof.
619TOY's build thread has the Prinsu rack here, 619TOY’s 200 Series Build & Adventure Thread This rack appeals to me because of the lower profile, also the price is very reasonable.
The Rhino Rack is another option, but the rails with the slots appear to run longitudinally along the rack. I have a Yakima rocketbox that I need to attach to the rack on occasion, and it looks like lateral slots of the two previous manufacturers would make that task easier.
I can only look at so many pictures online, I need to see these racks in person. Anyone in the Denver area have one of these installed on a 200?
Personally I like the idea of having room under the rack as well as on top, seems silly not to utilize that space (as long as you can still fit in your garage). Future plans include mounting a table as suggested above as well as solar panels that can slide out once parked. And since I'll be using the Blue Sea ACR 7622 adding a solar panel should be really easy especially if you run power/wires with solar in mind (in addition to rack mounted lighting, etc...). That said... I am still undecided on a rack.
Could you do a long and narrow table to the right or left of the shark fin w/ the K9 and not move it? I know you can't use their built for the rack table but I was thinking one could be made custom for half the cost haha...Eezi-Awn's K9 Roof Rack is also an aluminum option. I have been very pleased with my 2.2m.
The option of storing a table, solar panels, or both under the rack is also available on the K9. The only issue is the rear fin/antenna on the 200. I know someone has done a relocation of the fin in order to accommodate the table storage. Thinking of doing this to mine in the future.
You should be able to adjust your garage door limit setting enabling it to 'tuck' up entirely behind the opening and out of the way of the opening itself - LiftMaster Troubleshooting: Door Opens Part of the WayFor those with the Front Runner Slimline II, which is the current model available (and at Slee which is a plus, local for me), what is the total height of the vehicle with the rack installed?
I'm (currently) not lifted, but have the TRD Rock Warriors with the 285/70R17's, which is slightly taller than stock. My current total height is approximately 82", and my garage opening is at 84", but I lose some of that difference due to the garage door hanging down some at full open at the garage entrance.
