There's no order number, I just went back and forth with Tim on the options. Here's what I settled on:I was reading on their site last night on the options. Could you share your order number so I could just duplicate your order for my truck. That is exactly what I would spec.
-Full length, large Expo++ bar
-3 plates, 3 towers per side
-2 reverse light tabs and 2 reverse lights (flood)
-Sunroof cutout
-3/4 mesh (everything but the sunroof)
-8 gussets
-Powdercoating
-6 200-series towers (+hardware)
-2 light tabs in front and 40" light bar
-2 light wiring harnesses (one for front, one for rear)
-Fairing
I believe I have the first Gamiviti rack for a 200 series, so if you tell him you want the same options as the 200 series build he did he'll probably know.
Not sure if you have a 200 or an older cruiser, but here are a few notes on my build:
-I had Tim add front facing light bar tabs, so I could mount the light bar in front of the fairing. If you don't intend to mount a light bar I wouldn't opt for that design because you'll have to cut slits in the fairing for the tabs to slide through.
-I don't know if Tim can cut out the center rear-most grid bar, but if that can be omitted you'll want to do that. It doesn't make contact with the antenna on the 200, but it's very very close and it sits right over top. I do notice XM takes longer to lock in a signal if it gets lost driving under an overpass.
-The fairing is a must for wind noise on the 200. The ideal fairing size would be about 1-1.25" longer on the bottom (since the 200 slopes more near the windshield than the 100) and 1.5-2" wider in either side.
