roof rack mounting
Bend, OR
a friend just made a roof rack for me.
the tubing is 1" 0D 14 gauge
the flat stock is 8" wide and i don't remember the thickness its less than 1/4 and thicker than 1/8
the materials were $120 at keening metamorphisis, this is a artsy fartsy metal yard here in Albuquerque that i love, theyre so helpful. if your looking for a little piece of pipe for a project they will help you scavange for 10 minutes for a 2 dollar pipe.
I ordered 8 of these gutter mounts for $136 including shipping
http://www.4wheelparts.com/Exterior...unt.aspx?t_c=3&t_s=82&t_pt=8875&t_pn=KAR50541
And I payed my friend 100 bucks to build it
so all in all it cost me $ 356
its 84"x52"
My question is has anyone else used the clamps?
and when i mount this should i put some cut up hosing or something under the clamps or just go metal on metal?
They should work, I made my own clamps cause I'm cheap ;)
But you only have 1/4" or less between the bottom of the gutter and the top of the door, this was another reason I was weary of ordering a non specific clamp...
Good luck, post up some pics when it's all done!!!
I use a door edge guard as it's a little denser that rubber tubing
98 Snake Eater
That is the nicest most well planned and executed roof rack I have ever seen. Speaking of seeing......with the 9 million lumens of output your lights provide you will never have a problem in the light department. LOL
Job well done!
thats bombdigitty. I'm excited to go pick it up tonight. unfortunately i had him build it 52" outer dimensions and 1" tubing so the inside is only 50" and its going to be really close to the same size as the mounting plates. we will see how it looks. i didn't have the gutter mounts until he already had the outside bent up and welded together
An outstanding example of fine workmanship and a quality end product, well done SNAKE EATER. From concept to Install.
Thanx guise :cool:
Very nice, 98 snake eater. I want. Is that LineX instead of paint? Does that quiet the interior at all?
There are a number of coatings....
1) The steel joints were coated with weld-thru primer before and after each weld (gray stuff)
2) Once in the booth, everything was coated in etching primer (tan stuff)
3) Then coated with epoxy sealer (gloss black stuff)
4) After that, I hit it with a few coats of U-Pol Raptor bed liner (gritty black stuff)
As for quieting the interior, the Raptor stuff does reduce road noise slightly, but because of the way it hardens like a rock, it's not exactly the best choice for sound reduction :meh:
You'd be better off with something like Lizard Skin or Spray Dead or what I used to use back in the day (not sure if it's still available), sumthin called Road Kill Spray by Stinger :hmm:
It's basically a cleaner version of rubberized undercoating that stays soft, but isn't sticky after it dries like traditional undercoating :cool:
Works great in tight areas where it's difficult to apply DynaMat like door and kick panels :)
To the OP - have you mounted this yet? If so can you please post up some pics of it? I just ordered my Kargo Master gutter mounts (ONLY 8 bc I'm not as extreme as Snake Eater ;)). Mine will be for hauling canoe/camping gear, but one of my must-haves for this is that it's large enough to haul 4x8 sheet goods (preferably sitting down inside the basket to evenly distribute the load). So I'd love to see your setup and see how it works out before I get mine fabbed up.
Thanks,
Kyle
