Roof Electronics
Hanford, Ca
Website
instagram.com
So I'm headed to pick up a Full Length Inti Rack soon. You know, the old one that everyone wanted. I've decided on puting an LED light bar on it and some back up lights. I'm running the wire through the roof of the truck with an 11 pin Cannon plug. Each contact can handle up to 24 amps and uses a 12-14 guage wire. Besides these lights what are some other things I may want to add to the top of the truck? I figure I have 2 dedicated grounds and 7 more power wires I could tap into. Any suggestions?
Cannon plugs are easy to get from work. I'd probably get arrested trying to take a flir home.
Fat Fingered from the 'Mud app
Outside a front facing led bar, you could install a light on each side and a couple on the back. I love the side lights for night trails lighting up the sides of the truck.
Info on the Cannon plugs? Waterproof?
I had plans on the light bar and back up lights I was also thinking about adding a light to each side with a switch on the light itself. More along the lines of a work light not so much a driving light but it could be turned on on the trail for sure. As far as the plugs go they're great.
Cannon plugs are the ****! Spendy and bulletproof.
That pretty much sums it up. I got the plug and socket for free at work out of the "never going to use" parts bin. If you really wanted to know it's a plug for a ground cooling fan for an f-18 A/B which the Navy doesn't even fly anymore outside of the Blue Angels. This one has 11 really thick pins. I work on Super Hornets and we don't have anything this stout that I've come across. I had to order the pins myself and that was 45 bucks after shipping so the whole thing cost a bit of money. You can find a cheaper one out there though. Check out Newark.com You're looking for Circular Connectors and Components. This is the plug that I have and this is the receptacle on there. Plus a back shell which isn't cheap you're looking at a few hundred but you'll never have to worry about it really. These fail a lot on the aircraft I work with, but that's because we abuse the hell out of them. Usually it's a bent pin that will do a plug in, but they are easy to replace. These pins are thick enough that I shouldn't have to worry about it. I was actually looking for a 5-6 pin but couldn't find one in the bin so I just grabbed this one. I highly doubt I'll find use for all of the pins unless I ever add a tent; which isn't likely.
A lot of the $100k+ trophy trucks use Cannon plugs. I may or may not have one or two ;)
I'd actually be surprised if you didn't to be honest.
The Cannon plugs they are referring to are MIL-DTL-38999 connectors. The one ElPollo is using looks to be an Amphenol part, not Cannon. Several manufacturers build 38999 connectors including Amphenol, Cannon, Deutsch, Glenair and others. You can find the milspec on Assist and read all about them.
When we get them we don't know who the manufacturer is. They all use the same generic part number, I assume for MIL-STD reasons. We call all of them Cannon plugs no matter where they come from. I just linked to a common part number on the site. I have another one of these, it's much smaller and each pin is only capable of 5 amps. I think it's a 6 pin I think and I have the pins for it. Not sure what I can use it for. If anyone wants me to look into these I have access to all types of Navy publications, I can get a lot of part numbers if you're looking for something specific. As long as it's not classified I can provide some info.
I may take you up on that. I use thousands of LEMO connectors which is the a very non-military equivalent.
Got my pins in today from Newark.com. They messed up the order and sent me 14 pins and 10 receptacles. I was on the phone for 2 minutes to get it fixed and they are sending me two more receptacles at no extra charge.
Part numbers
The pins connected. Going to get some 14 gauge wire and build this when the rest of my stuff gets here.
All plugs are Cannons just like all pop are Cokes... LOL. That's what my southern shop Sargeant told me back in the day.
What about an LRAD to go with the FLIR... Plenty of night missions doing SAR where I wish I had one for sound sweeps in the wet NW woods...
Good to see the rack with have lights once again!
See ya on Sat!
Dude never put it past a ground pounder, squid, zoomy or jar head to simplify things... LOL!
One word for them all. Anyways those plugs are bullet proof so you should have some really good connections for your setup. One might almost say overkill? Naaaawwww!
See ya on Sat!
Can't wait. I'll give you a call when I get into Sacramento on Friday.
Like no one on 'Mud has ever done that before. Ha Ha.
