Ring Gear size
Mississippi, Southern part
I have two set of ring & pinion gears that supposedly are for an FJ40. Both ring gears have 37 teeth and the pinion has 9 = 4.11. Both have 12 mounting holes that match each other.
This is the question: one ring gear measures approximately 9.25" side to side and the other measures 9.5".
Was there a difference in ring gears front and back?
Or is one from a different year range than the other?
Gary
No difference front to back. Maybe slight changes over the years of production runs. Are they fine spline or coarse?
I assume your talking about the pinion splines? if so, I'm not sure. How many splines on the course and how many on the fine?
. . . one ring gear measures approximately 9.25" side to side and the other measures 9.5". . . .
Are you measuring the back surface or the face with the teeth? I wish I was at home I could measure mine that I pulled when I rebuilt both axles.
Interesting, I've never noted a difference. You have found something new. I don't have any coarse spline pinion gear sets left, so cannot independently measure.
There are slight differences in ring gear diameter based on gear ratio. I believe 4.11 has the largest ring gear by a few mm.
One of yours is OLD. I believe the threaded holes in the ring gear were pre 1969 but I'm not sure.
If you're in an upgrading mood, this is a good time to gear with fine spline ring and pinions which are stronger.
