I'm replacing my front ring and pinion in my Lexus lx450does anyone have any suggestions on replacement ones .... or none expensive ones ... I also am having trouble finding a bearing kit any help is apretitated
gears are specific to the axle type. Dana 44 is an axle not found under your LX. you need an 8" reverse cut high pinion toyota gear set
Exactly my point. Some folks confuse the different manufactures of the 8/8.5" diffs.What are you talking about? The LX450 doesn't use the Dana 44 axle.
I'm saying you don't think I could use one even tho it's the same gear ratio .... I don't get itgears are specific to the axle type. Dana 44 is an axle not found under your LX. you need an 8" reverse cut high pinion toyota gear set
I was looking up my gear ratio and found out that I can get a ring and pinion with the same gear ratio 4.1 for my truck but the brand is Dana 44I'm guessing he is thinking of possible interchange with Taco axles that were domestically manufactured?
It's got broken teethWhat is wrong with yours? If it's not locked, used market maybe best, just swap the whole third?
