rewiring
NC
Website
www.svmatch.com
I have a 78 Fj40. I have no idea what is original wires or what previous owners added. There are wires everywhere. Lots of wires cut and have no use at the moment.it is a complete mess. I have problems with the gauges and I think the wiring in this Fj40 is half the problem. I would like to rip it all out and install all new wire. I know painless and EZwire offer kits. It currently has the 2F engine and would like to do the v8 conversion years down the road. What do I need to totally rewire this vehicle. Considering my experience a kit is best suited for my ability. I would even consider taking it to a shop and having them rewire it. Are there things in the kit that are not included that I would need to purchase as well? Anyone ever have a shop rewire your cruiser and what did it cost? Any info anyone can provide would be greatly appreciated.
This is kind of a specialty of mine. We remove, untape, repair wires and connections/connectors with solder and shrink wrap, add your wish list of accessories and remove what you dont want, then zip tie it every 4 to 6 inches and reloom it in split loom. You will need to map out where you want things, like relays for lights on fenders, driving lights, radio/cb, extra power supplies, etc.. Its a tab bit more expensive than kits but it keeps the factory flavor, runs 295 for the complete process and usually I do the accessories for free just depends on whats asked of me. Let me know If I can help you, be glad to offer any assistance I can. Drop me a pm or ring me at the shop 501 821 4737
Bobby
:cheers:
If you don't go with the above option, I used a Painless wiring harness in mine. It's not completely painless, but it helps a LOT. The most trouble is routing the wires and then connecting them. If your plastic connectors are in decent condition, reuse them. Mine were shot, so I ordered Deutsch connectors off of Terminal Supply Co. Painless includes a how-to book, and coupled with a Haynes repair manual with the wiring schematics, will be enough to get the job done right. And the Painless harness has the capability to be added on to later on down the road, and every single wire is labeled so you know exactly what wire it is. Some fabricating will be necessary, but it makes the process go by quicker and easier. The kit contains fuses, connectors of several varieties and gauges, gromets, and the necessary hook up for your headlights. You will need a lot of butt splice connectors, a crimping tool, good wire cutters, a multimeter, a couple rolls of electrical tape, and a few bags of zip ties, plus a lot of patience and a good head of logic. Whatever you choose, best of luck, and if you decide to go with the Painless don't be afraid to email or PM me. Cheers!
mtj555 said:
I have a 78 Fj40. I have no idea what is original wires or what previous owners added. There are wires everywhere. Lots of wires cut and have no use at the moment.it is a complete mess. I have problems with the gauges and I think the wiring in this Fj40 is half the problem. .
All wiring looks like a mess. To me, it sounds like you could solve your problems by spending 30 minutes looking over the shematic diagram. As luck would have it, there is one posted for '78 FJ40 in tech links. Original wires are easy to spot and know what they do because they are color coded to match the color codes on the schematic. They also end at OEM connectors. (The start and Acc color codes on the ignition switch are incorrectly interchanged on the diagram). There aren't that many wires to deal with for the gauges. You also want to look up any cut wire on the diagram to see if it is important. If it is running, it probably isn't.
I also used the Painless harness; feel free to PM with questions.
amg2y said:
Dan, which EZ kit did you use?? I am planning to get one of those too.:beer:
I used the EZ 21. It has way more circuits than i actually need, but I figured it was easier to add stuff later if the wiring was already there, and I could just hook it up, than to tray and add entire circuits later. I also went to Waytech wire and go a bunch of shrink wrap, connectors terminals, split loom, etc. Project would have gone really fast, it I had more time to work on it. I think about 6-8 hours total, from tear out to firing it up. It would definatley be faster the next time.
