The biggest problem with changing from 9mm to 10mm none of your wheel cylinders ,''T'' fittings,and drop hoses, will Not be reusable or you will have to use adapters or use all 10mm stuff.
Going to 10mm and 4 wheel Disc brakes at the same time make sense, Most people that go this wrought want a brake booster,then you are looking at the fire wall rib and the carburetor issue,some have used a firewall spacer. Then again I would Use all new parts too.
Degnol, used Corvette Disc brakes M/C with 4 wheel Disc, this is what I might have used, If I went that route.
Mark A of marks off Road uses a later style 10mm duel master cylinder to split front and rear drum brakes by using compression line fittings to couple back onto the 9mm line and welds over the "T"( I may go this way later )
There are Many ways to deal with brakes in the FJs in the end I went with the Original OEM Design.
I went and rebuilt the OEM single circuit Master and drum brakes,Using 95% new parts including new brake lines. Now I have a original Toyota design brake system and It works just like Mr. Toyota Designed It.
Then sold my DB front Axle and other 4 wheel DB parts. Call me Crazy
Is It Old School yes It Is ! Is It Safe I think So. as long as you inspect It and make adjustments 9mm works just fine.
My FJ40 is not my daily driver I wish It was,so If something not working right I don't drive It.
and I have anouther 4X4 If needed
Is It $$$ to rebuild your braking system Yes It is !
I would not re-use junkyard brake parts for a rig that is driven on the streets.
I have Re-learned how to adjust drum brakes again now I can adjust all 4 in about 30-40 minutes
I am very happy with the results....Joe C
