Thought some may like to follow along. I have started the resurrection of a 1991 FJ80 3FE. First step was to replace the fuel pump to get her in the garage. Got the radiator out last night. Obviously there is plenty of leaking. Would love some advice on what I should replace now that I have the radiator out. Going back with a CSF radiator once I have replaced some items now that I have room. Inside has had water sitting in it for about 8 years. I believe its coming from the windshield and pooling in the foot wells. I would appreciate any recommendations on getting a baseline and idea where it could be leaking (Im guessing Power steering pump and I know Valve gasket). Below is what I have purchased and is on hand. Thanks and I will continue to post my progress!
| AUTOBEST | F239S | Fuel Pump Strainer |
| AUTOLITE | XP64 | Spark Plug |
| BOSCH | 68200 | Fuel Pump Gasket / Seal |
| CARTER | P90012 | Fuel Pump |
| DENSO | 1432097 (143-2097) | Air Filter |
| MOBIL | M1301A (M1-301A) | Oil Filter |
| STANDARD MOTOR PRODUCTS | 55935 | Spark Plug Wire |
| WIX | 33500 | Fuel Filter |
| WVE | 5D1304 | Distributor Cap |
| WVE | 4R1142 | Distributor Rotor Private Label Package |
| Relay | Novita Technologies Novita Technologies 13.5 Amp 3 Terminal Turn Signal Flasher | Flasher |
| Relay | Import Direct Ignition Import Direct Ignition 10 Amp 5 Terminal Multi-Purpose | Multi-Purpose Relay |
| Relay | MasterPro Ignition MasterPro Ignition 22 Amp 4 Terminal Multi-Purpose Relay | Multi-Purpose Relay |
| Relay | Blister Pack Littelfuse Blister Pack 60 | Amp Fuse |
| Fuse | Blister Pack Littelfuse Blister Pack 10 | Amp Fuse |
| Fuse | Blister Pack Littelfuse Blister Pack 7.5 | Amp Fuse |
| Fuse | Blister Pack Littelfuse Blister Pack 15 | Amp Fuse |
| Fuse | Blister Pack Littelfuse Blister Pack 20 | Amp Fuse |
| Felpro | Felpro Valve Cover Gasket Set | Gasket |
| Battery | EverStart Maxx Size 24 | Battery |
| DORMAN | 42058 | Positive Crankcase Ventilation (PCV) Grommet |
| MAHLE | SS20218 | Valve Stem Seal |
| STANDARD MOTOR PRODUCTS | V281 | Positive Crankcase Ventilation (PCV) Valve |
| VICTOR REINZ | 711652400 (71-16524-00) | Throttle Body Gasket |
| Toyota | 90210-13001 | Valve Cover Washer Seal |
| AISIN | WPT029 (WPT-029) | Water Pump |
| APEX | AWP3095 | Water Pump Gasket |
| CONTINENTAL | 49032 | Tensioner Pulley |
| CSF | 2709 | Radiator |
| DAYCO | 89039 | Idler Pulley |
| FEL-PRO | 35307 | Thermostat / Thermostat Housing / Water Outlet Seal |
| MOTORAD | 245180 (245-180) | Thermostat |
| US MOTOR WORKS | 22076 | Radiator Fan Clutch |
