Reset Check Engine Light?
Denver
Just cleaned the motor today with a high pressure washer....got a little too wet. Runs fine now that it is dried out. Check engine light came on during the drive home. It started flashing...then just stayed on.
Carwash is less than 1 mile from home. Let it sit in the garage to dry, restared, all is good, but light will not go away.
I have the 1996 Toyota Land Cruiser Repair Manual, but cannot seem to find the simple directions on how to reset the light.
Anyone help out?
Schroder
If it's just the water incursion from your engine washing, the light will probably go out in the next day or so of driving (assuming whatever it was that triggered it was two-trip logic). If not, you can pull the ECU fuse, or disconnect the batter for about 10 minutes (which will also erase any stored info on your radio, so don't do this if you have a security code set that you don't remember...).
Also was just reading some other threads...pull the EFI fuse? I think I will wait a few days.
I will be back in a few days to post the results back to this thread.
Thanks!
Thanks!
Not the EFI fuse...the ECU (computer) fuse.
Pulling the 15A EFI fuse in the engine bay fuse block for a period of 30 seconds will reset the check engine light and remove the stored codes from the computer. Yes, EFI.
You can disconnect the battery also, just pull the negative cable.
It's OK! It won't harm the engine..... It will clear the code........... I'm a bit curious though what code did it pull? Are you near a Autozone? They scan OBD codes for free.
I will find out. Done a lot of reading since I first posted this earlier tonight. Romer hooked me up on this site.
Once you get that fixed, you need to modify it for safety for your wife. Get sliders and an ARB bumper. Show her this thread:
https://forum.ih8mud.com/showthread.php?t=50707
Once you get it modified, then buy her a diiferent vehicle and take it for yourself.
Welcome Schroder
Gonna borrow an OBDII, will pull the code, and post it prior to any resets. Check back Friday.
Just reset mine--pulled EFI 15amp fuse from fuse box behind battery. Worked like a champ. Also went to autozone and got them to read the code for free. Ended up being 420. Not worried about it as I just replaced both 02 sensors from CDan and if it is a bad CAT it won't matter as the county I live does not require emission tests--gotta love the country!
Dave
Fuel consumption has been stable 14-16mpg hwy
