Replacing washer hose??
Dallas, Texas
Website
www.flickr.com
How do yo get to the washer hose behind the glove box.
I am trying to get it out. Do I have to fold the windshield?
Antoine
? what washer?
On a '78 the windshield washer is at the top of the windshield. The tube from the pump/reservoir goes through the dash, and up through the windshield frame.
I would've answered if I had _any_ idea how you'd get it up there. Ideally you'd use the old hose to pull the new one in. The tube feeds up the same hole as the dome light wire on the driver's side. I think you could get it in there with the windshield up, but probably not with the top on.
I used a length of 1/4" irrigation tubing that I fed up through the bottom corner of the windshield frame next to the glove box. I used irrigation tubing because it has the right stiffness to push and will make a turn. At the top corner of the windshield frame i twisted the tubing and it made the turn and then I pushed it until it presented itself at the spray nozzle. I then attached the silicone tubing I was using to replace the metal and plastic tubing to the irrigation tubing and pulled it through the frame. The silicone tubing is flexible enough to make the 90 degree turn to attach to the nozzle fitting without obstructing the flow. I then took the other end of the silicone tubing and routed it to the washer pump making the entire circuit with one length of tubing. I also installed the factory sprayer to the hood and attached the tubing using a tee at the pump outlet. No more issues with rusted steel washer tubing.
Antoine
To answer your question....
Yes, there is a connection in the lower portion of the window frame.
Inside the frame is a metal tube. Connections are at the bottom and another soft line that is attached to the hard line and into sprayer at the top. The line on top is about an inch+ long.
All this is true if your sprayer is on top of windshield. Some years have E.T. On the hood. And apparently if creative enough..... You can have both. Which is my intention at the end of my build.
My question would be.... Since I thought I started with an all original 78. Mine had both already, did that ever happen from the factory??
( Although not both were hooked up....)
I have both the ET and the one above..
I didnt know where the steel hose ended. If anything i can just use the ET one.
The metal one rides inside from bottom to top. (I assume so you don't have to fish it through)
If you remove the top sprayer you can easily see the steal line. With window folded down you can easily see bottom portion of metal line. Both are readily accessible.....
Just tore my frame apart monday for sandblasting.....
So I have to fold the wind shield?
:frown::censor:
Double washers? Cool.
Where is the steel tubing?
The steel tubing is still there. I just ran a new silicone tube bypassing the steel tubing. There is enough room to have both in the frame.
:frown::censor:
Dude, did you even bother to read my post or are you determined to make this as difficult as possible?
I've never seen the metal line coming out of the bottom of the windshield when it was folded down. Driver's or passenger's side?
My windshield frame is all rusted from the inside out. I wonder if it's related?
Just seeing this now..... Will snap pics tomorrow. It's in there.... At least it's in mine.
Passenger side. It's inside the frame but accessible. Soft line up through dash and cowl into hard line.
Like many things not sure if it is year specific???
If you feed a tube loose thru the windshield you take a chance of it vibrating around and causing a hole. Probably the reason for the steel tube in the first place. You get to the top hose by removing the inspection rubber plug at the top center if the widnshield on the inside. The OEM part that attached the spray nozzle to the steel tub was molded rubber. It's a small hose. If you use something else make sure it doesn't kink. It's a short piece that bends 90 degrees.
Passenger side bottom
my hose was leaking where it connects to the steel tube or perhaps the steel tube is rusted. In any event i tried to fish a new line up the hole and gave up. Instead I ran a fish line thru frame to the driver side. There is an identical hole in frame on driver side. Pulled a new rubber line thru. Connected to squirter and then back to original hose at glove box. Total bypass of steel tube.
