replacing diff pinion oil seal
Victoria, Australia
As above I am replacing the oil seal, now on removing and refitting the flange bolt do I have to hold the flange from turning some how or is it ok to allow the gear thingys in the diff hold it as I undo and tighten nut. Any other tips would be appreciated.
BJ
Use an impact wrench. It can be done with a breaker bar but you gotta keep the truck from wanting to move forward or back with the parking brake and/or wheel chocks. Carefull putting it back together using an impact as there is a recommended torque setting. Sounds like you need to buy a factory serice manual (FSM).
Make a "tool" to hold the pinion flange by drilling a couple of holes in a piece of angle stock and bolting it to the flange to prevent it from turning. You need to torque the nut to about 150 ft lbs.
Check the outer pinion bearing and the preload shims for wear and scoring. Sometimes seals leak because the bearing is bad.
Also measure the overall torque it takes to turn the pinion with the wheels off so that you know if you have overtightened the pinion. After torquing the nut, the turning force should be the same as before +/- 1 ft lb.
When I first did this, I some how managed to push the pinion into the axle. I don't know if it can fall all the way in where you'd have to disassemble it completely, but I thought I might have.
It will hit the carrier and stop...no biggie.
:beer:
