Replacement steering rack in us
Colorado
Need to replace my rack as it is leaking
The part number is 44250-60010 or 44250-60011 depending on the year of the chassis. I need to check when mine was. The break is before and after 08/1997 and mine is a 97
I’m not seeing any oem toyota ones but some aftermarket. Has anyone had any experience with any of them and can vouch for the quality?
Thanks
Edit looks like I’m Feb 97 so I need the 44250-60010
Well for better or worse I ordered one from alibaba for like $300. It’s probably a pos but I can’t really find a oem one sub 800-1000
A local guy said he “might” be able to rebuild it if the seals are the same as the t4r for $400. I might take the oem one to him and keep it as a spare
-60011 is a supersession of -60010. -60010 is no longer manufactured. -60011 is the only thing you’ll be able to get.
Ownership of a non-US LC only gets **more** expensive the older it gets.
$800-1000 for a OEM rack is a great price and rivals what OEM racks are here in the States for USDM Land Cruisers.
I think in short order you’ll be doing this twice and spending double the money for parts and labor.
Caveat emptor.
I just replaced mine with OEM. Not cheap, but worth the peace of mind. Planning to rebuild my old one using OEM kit.
There’s quite a bit of slop in my old one. The new rack really made a difference in steering feel but I’ll keep the oem rack and rebuild it if this one fails.
Apparently I did a poor job of centering the rack.
Rather than removing the rack to clock it I am thinking the easy way might be have the rack aligned centered with the steering wheel crooked and remove the steering wheel and re clock the wheel. 🤷‍♂️
