- Joined
- Mar 9, 2014
- Threads
- 50
- Messages
- 1,298
- Location
- FL Panhandle. Pcola/Miramar Beach
- Website
- forum.ih8mud.com
- Thread starter
- #21
Missed that little detail at first glance but it does say it includes the door lip.
...via IH8MUD app
be careful when you cut the top of the rocker at the back piller. ITs a taper and very hard to match. I was lucky with a little grinding got it to blend in. I was happy with real steel but I only did my outer. This is the stuff to spray in after you weld . Its the can of stuff with the plastic tube. http://www.eastwood.com/internal-frame-coating-w-spray-nozzle-qt.html
You will need a very small recipicating saw to cut the old one out in the picture i sent you its that top joint on the rear piller. Every thing else makes to big of a cut. Its the only thing I found easy to use. Got it from Harbor Freight.
Just lining up my Real Steel rockers and something isn't right.
It's aligned but about 1/2" too short (yes I ordered the appropriate year).
Anyone else have similar issues?
What was your solution?Yes, exact same issue on mine. But I noticed before I cut it, also seems the panel is not as bent as dramatically as the stock one.
Thanks for sharing, glad to know I'm not crazy.Just cut it differently, wasn’t what I wanted to do but worked out okay.View attachment 2530348View attachment 2530349View attachment 2530350View attachment 2530351
