Replacement for Water Temp Switch 89428-60060
Boston
The Water Temp Switch 89428-60060 has been discontinued but did find this on Pats Geek: 1988 Toyota Land Cruiser Engine Coolant Fan Temperature Switch. It definitely looks the same and is $100-$150 cheaper than than 89428-60060 on other sites.
i have Genuine NipponDenso Made in Japan Spec. repair / Refresh / restore kits ...
the new updated same updated nippondenso plug connector too ...
- do NOT be fooled by some folks recommending a 13$ Toyota black tip 22R Turbo BLACK TIP sensor , it has a 27"F threshold difference , and there recommendation is incorrect
below is by the book correct for you 1988 ...
@ToyotaMatt i made an order for the cold start switch with you, please add this to my order as well. when I made my order I couldn't find the water temp switch :/. my truck hard starting in the cold... at least 10 turns of the key before it will start. once warmed up it's fine. Thanks!
@ToyotaMatt i'd like to buy the water temp switch. if I order it will you send with the cold start switch (black tip sensor)?
i can do better and ship the grey tip sensor out Today for you if i know in next 45 min. is my daily USPS PM RUN cut off time
as i have not received my JAPAN stock order with more of the black tip larger Timer sensors switches yet
you are going to incur any additional shipping fees for the Black Timer sensor switch , as that my responsibility now of course ......
please let me know when you decide on the grey tip sensor , i am BILLY the Tape Guns Kid right now , one in each hand going at it hard .......... :D :wrench: :wrench:
thanks !
thanks !
Thanks @ToyotaMatt! I just ordered the gray-tipped sensor from you, order# YXYPXY0L5. I changed the thermostat today and the connector on my current gray-tipped sensor crumbled in my hand, ugh. If you could drop it in the mail tomorrow it would be very appreciated. Thanks!
order # in a 4 digit one ?
like 4444
@ToyotaMatt I'd also like to purchase the hard pipes - rear heater tubing (87208A) that we discussed in another thread. Can you send me a link for the rear heater tubing? Thanks!
