Replacement Dash Cluster
Florida
I just purchased from an overseas dealer a replacement cluster for my 1976 FJ. There is a 3 prong attachment in the back that my 1976 FJ 40 does not have. Will this still work with my 1976 FJ?
I believe that is correct so I think I will need to wire this independently. There are five digits and a tenth in the odometer. I am hoping everything else will work!
did U purchase a 83100-60180 ?
If so Your old 1976 AMP meter ring terminals are NOT compatible with the 3 Terminal connector on the back for the New Now 50amp meter
Yes - this is the cluster that I bought.... is there any chance of making this work? I read one forum where a FJ owner did this and had a special connection wired for the amp meter.
The older style ammeters are wired in series with the main power feed to the fuse block. The newer, 50 amp meters are wired across a shunt. You’d have to wire in some type of shunt to use this ammeter without frying it. I’m not sure what the resistance of the factory shunt was.
