Can you guys tell me if I can replace the rear cross member? Went out to start pulling the aftermarket bumper off and realized they welded the damn thing on. Not exactly sure what’s going on and what’s stock vs not. Your wisdom is appreciated.
That’s what I was going to try. Are those the stock hangers?Well that sucks for sure. More proof that some people should not own a welder! If the cross member is solid I would get out the cutting wheels and see if it will be easy to separate the bumper and cross member. I have found in the past, many times, that the people who should not own a welder typically do a crappy job of actual penetration.
I think it was @Awl_TEQI removed my crossmember to straighten it once, decades ago. You'll become proficient at removing rivits. You'll have a couple of welds to cut too. I think there's a vendor that sells aftermarket crossmembers on this site. Idr, his name.
I removed my crossmember to straighten it once, decades ago. You'll become proficient at removing rivits. You'll have a couple of welds to cut too. If you can't save it, I think there's a vendor that sells aftermarket crossmembers on this site. Idr, his name.
Good for him. I wish I had spent more time doing that when they were younger. Time goes by so fast.....I'm pretty sure he is semi-retired from making cruiser parts for a while, spending more time with the family.
No. The placement is not original too and the rivet is missing.That’s what I was going to try. Are those the stock hangers? View attachment 2267574
There are rivets in it just couldn’t see. Still think not stock?No. The placement is not original too and the rivet is missing.
