Repack or Rebuild?
Traverse City, MI
Website
www.myspace.com
Regarding the birfs, I have heard alot of mention about "repacking" and "rebuilding". Anyone care to shed some light on the differances and when one or the other is the right way to go.:confused:
I believe repacking tends to relate to the bearings. Refer to the thread FAQ for 80/LX450 series and scroll down the maintenance section. In there is a thread on the Front axle service. That thread constitutes a rebuild changing seals and gaskets. Repacking the bearings would involve just taking the hub off and cleaning the bearings and repacking them with grease. You need to roll the bearings to get the grease inside.
I suppose some could use the term to re=pack the grease around the birfs, but you have already done the tear down, so why not replace the seals and trunnion bearings.
I would say that in many instances these terms are probably interchangeable. I would replace all seals and bearings as well as repack the grease. If you are going to get in there, might as well take care of all of it
Ahhhh coffee does wonders. Repacking does apply also to repacking teh birfs with grease. Thats what happens with a late night and early morning.
In my own little world...
A repack is a tear down, replace all lubricants, reassemble. This means birfs greased, bearings greased, gear oil changed, housing cleaned out and refilled. New parts are confined to seals and items that are worn to broken.
A rebuild is replacing or remanufacturing of all wear parts. Removal, inspection and replacement if worn of birfs, bearings, drive flanges, etc... Any part that shows wear gets changed or remanufactured. All new seals, lubricants, etc..
Obviously the rebuild costs more. I think it would be reasonable to expect several repackings per rebuild.
IMHO... If your birfs are clicking, you have substantial wear. A repack is good before the wear occurs, but if you're clicking, you should rebuild.
I did a rebuild on my grey truck @ 125,000 miles. It was clicking pretty bad. It got new longfield birfs & axles, new bearings, regular (not synth) grease. I plan to pull it down inside of 2 years (~10,000 miles) to do gears, so extended life of the lubricant was not a big concern.
My wifes red truck has 116,000 on it. I'm planning to repack it in the late spring. If it starts clicking between now and then, I'll be rebuilding it instead. If any of the bearings show wear, they're gone. I'm planning to switch her's to all synthetic lubricants in the driveline, brakes & transmission, but NOT in the engine. Not that synthetics are bad there, but they're IMHO a wasted expense. I'm still changing that filter regularly regardless of the type of fluid that drains out. I wonder how many people are driving 7,000+ miles on synthetics where the last 1,000+ of that has the clogged filter on bypass. (Sorry, I digressed.)
Repack = lubricants & seals
Rebuild = lubricants & seals & wear/worn parts
Grench, that was poetic my friend. Just the type of straight shootin i needed. So I will assume, since my birfs are quiet as a mouse, I can wait until spring time, pull them apart and replace the axle seals, the 3 layer knuckle seal, and fluid. If I see any worn or damaged hardware, that will be replaced as well. Can i ask Dan for a birf "repack" kit and get what I need?
BTW, I agree with you 110% regarding synth enigine oil. Alot for a little if you ask me.Nno disrespect to those with far more experiance that I, just my humble opinion. :beer:
