Removing steering rack
I think he means the pinch nut on the steering shaft universal joint..
I haven’t done this job yet so can’t comment directly.
That should be fairly straightforward… should be able to get to that from underneath. Buuuut I’m typically working with the vehicle on a lift, so everything is a little easier…
Yes I’m trying to get the bolt on the steering coupling u joint. Will try turning the steering wheel as @turbo8 suggested. That didn’t occur to me. There is another coupling up higher. I wonder if the whole thing could just be clocked 180° from where it is now. If it was, it would be easy to access.
Make sure you secure the steering wheel before you disconnect the steering shaft from the rack. This is so the you dont break the clock spring and to keep the wheel centered in it's rotational travel.
Yeah, I saw that somewhere. Is it correct to assume the clock spring is on its “neutral” position with the wheels straight? The point of securing the wheel is to make sure it doesn’t get turned past full lock when disconnected from the rack?
Yes. Go past full lock in either direction and you risk breaking the clock spring.
Securing the wheel can also be useful for keeping the wheel/VGRS/steering rack all lined up in the center.
It’s been five years but I loosened the fan shroud, unbolted the engine mounts and jacked up the motor as far as I could. I couldn’t get it out any other way.
I took Friday and the weekend off and back at it today. Got the rack all loose and just trying to figure out how to slide it out. I have not touched the engine mounting bolts yet. There is an oil cooler bracket that interferes, and the FSM says to remove it. I removed it and it’s super close to come out. The only thing hitting the engine are the hard hydraulic lines. I think I’m gonna just pull those lines off and see if I can snake it out without loosening the engine mounts. I still may loosen the engine mounts and jack the motor up a bit to get the new rack in. I’m not sure I really wanna take the hard lines off the new rack and put them back with the racking in situ.
This job is totally kicking my @$$. I just pulled off the passenger shock. The King 2.5 coil was preventing the rack from pivoting the whole way. I will can’t get it out and am currently stuck here:
I also tried pulling it out the Passinger side but steering coupler shaft and associated housing can’t be rotated enough to come out the hole. To recap I have:
1. Removed oil cooler bracket.
2. Removed oil filter
3. Lifted engine about 1”
4. Removed hydraulic tubing from rack
5. Removed passenger side shock
Waiting for a buddy to come over hoping a guy at each end will be able to rotate and position the rack to slide out. If not, the only thing I can think of is removing the entire oil cooler. I know @linuxgod said his shop did that but I’m not certain that is what is preventing it from coming out.
Could you unbolt the driver side sway bar mount at the frame and move it forward to sneak the rack out?
Yes, I’ve thought of that but so far it’s not the thing I hit. I think it’ll clear if I can get past the tie rod hole on the passenger side
Did you try hitting it with your purse?
Can you just not see where it’s getting stuck? That oil cooler probably needs to come out entirely. I’ve only done one LC rack and I don’t remember much about that job other than “it wasn’t my favorite.”
I’m beginning to wish aI had just paid a pro…
It’s very close to coming out it just. It’s hanging up in the tie rod whole. It’s hard to rotate it while lifting with it with my foot while on my back under the truck guiding it past the oil cooler. A buddy is coming over latter and we’ll see. I don’t want to take the oil cooler out if I don’t need to. If I do take it out do I need to drain the radiator first? The FSM says to drain both the coolant and the oil. I can see that radiator will probably drain when I disconnect the hoses but I’m not sure how much oil will really drain by removing the cooler.
Clamp or plug the coolant lines to the cooler, then remove it.
Joy!
I was able to pull it out all the way through the passenger side tie rod hole. The is a lot of rotating and angling it to wiggle it out. Needed to turn the steering to the right to shorten the drivers side and jack the KDSS link out of the way. KDSS may not have been in the way if still attached to the LCA but I disconnected it to remove the shock.
I put the hard lines back on the old rack and reinserted it through the passenger side whole to make sure it was possible with the lines attached to the rack. It worked and I was able to get the new rack in place w/o removing the hard lines except for the short 90 degree one on the steering spur great housing. That one I pulled off because it would just be two easy to hit it and bend it.
It was really hard to remove. Looks like they used some kind of thread locker as the threads have some white substance on them. I don’t think it is sealer as the fitting is a flare fitting and the threads don’t provide the seal. Not sure you are supposed to use thread locker either. I needed a breaker bar to get it loose.
FWIW I don’t think the oil cooler is that hard to remove. It’s 2 or 3 bolts and disconnect the cooling lines. I suggest new o rings and cooling clamps to before reinstalling but that’s only a few $
Not sure how hard it really is. The FSM has a bunch of stuff that makes it look difficult. They have you unmount the AC compressor and the hard tubing around the front of the engine. I’ve done all that before with the radiator out and it sucked. It does look like you could just undo the mounting stud nuts (I think there are 5) and pull the hoses. I’m just glad I got it out and back in without having to do it.
Not sure how hard it really is. The FSM has a bunch of stuff that makes it look difficult. They have you unmount the AC compressor and the hard tubing around the front of the engine…….
The FSM is “ideal.” But, especially if you work by warranty time, you learn that 75% of that s*** is going to result in earning minimum wage. So you learn to use shortcuts. As you saw, some of the procedure just doesn’t have to be done to get the job done. This usually happens at expense to your body.
I’m glad you got the rack out! That’s a “better you than me” kind of job 😂.
The oil cooler itself isn't super difficult to get off the timing cover, but there is a brace that goes from the bottom edge to the block near the AC compressor that is a total PITA... at least it is with the engine still on the mounts.
I’m finally finishing the steering rack replacement. I took a lot of notes and will post my detailed procedure when I get some time later.
I’m ing the system with ATF. The FSM just says to “bleed” the system by first filling the reservoir and then turning the steering wheel from lock to lock to suck fluid into the system. Maybe this works on a used steering rack that has once been filled with fluid but I’ve only been able to get 8 oz of fluid in and most of that is still in the reservoir. Should I try to pull the feed tube off and try to fill it directly with fluid so the pump gets something on its first crank? Could I pull the EFI or some other fuse and bump the starter to draw fluid into the pump. I’m afraid to just start the engine with the system mostly dry. There probably still is a little fluid in the system somewhere but I don’t know where. I don’t want to kill the pump.
