You really need to take the rocker assembly off to remove the head. It needs to be out of the way to get to the #1 head bolt, and you need to carefully disconnect and remove the brass pipe that brings oil up from below. I like to take off the side cover and disconnect the lower end and take it out before removing the head, since it can easily be damaged if you install/reinstall the head with it in place. You REALLY don't want it to leak.
I would also just loosen all of the valve-lash adjusting nuts and screws (any that aren't already loose) before taking off the rocker arm assemblies, so there's no pressure from opened valves as you're removing the assemblies. You'll have to readjust after the head work, anyway.
I don't know about sending the rocker assembly to the head shop. I've just worked on that myself. A good cleaning and inspection of the rocker arm support tubes for grooving/wear are the main work which you can do while the head is at the shop.
Wise to have the FSM for reassembly.
