Removing head question
bajaphile
Boojum Hugger
Solana Beach, CA
Hi all,
My first project on my 1966 is getting the engine running strong. It idles well, but, I knew there was a valve issue.
Ran compression today:
1 - 150
2 - 140
3 - 140
4 - 140
5 - 130
6 - 0 :doh:
I pulled off the valve cover, and turned the engine over a few times to see what the heck was going on...
It appeared the rods, rocker arm, etc were moving correctly on all valves, but, #6 exhaust was pretty much "stuck" in the open (down) position. It almost appeared that it was not "springing" back into its normal closed position.
I have never done a valve job, or know much. My FSM is in the mail, but, I'm too impatient to wait for it, sorry. I did search on this issue I swear.
My thoughts are either a bad valve seat or broke spring? I am assuming I'll have to bring the head into the shop reguardless...? Plus, I guess I wouldn't mind just having everything re-done. What is the general price on re-conditioning the head?
Also, are the head bolts the ones running through underneath the rocker arm?
Thanks for any help, here are some pictures .. donno if that helps. ;)
I'm guessing it's bent, at least. :frown:
Well....nice pics :)
You'll find that there is one head-bolt that runs in the center of the head...just under the rocker rod. Be sure to slowly back off the pressure on the head bolts. Loosen each one just a little bit at a time. This will help in lessening the likelyhood of warping the head.
Be sure that when you have the head re-worked at a machine shop that they put hardened seats in there! Back in '66, they used leaded gas....obviously we don't any more and the older F motors need leaded fuel to preserve the valve-seat life. The hardened seats will remedy that for ya....also last much longer!
You'll likely get out of the machine shop for around $300 less in your back pocket, but your truck will run so much better with fully adjusted valves.
Post up more on this as you progress.....curious about how ya do!
yes, the head bolts go along both sides of the head...on the passenger side they are under the rocker arms and on the right side they are pretty accesable. a #17 IIRC I had to take the rockers off to get at the ones on the left side of the engine wait for your manual before you go messing with your head bolts...you have to take them off in a certain way and i dont really know how to explain it, the picture is worth a thousand words
OH....My guess is that you have a broken valve spring. This would be a possible reason for it not closing the valve. You can get a new spring in a set from your machine shop.
Also, while you have the head off....have it magnufluxed. Checks for cracks, and it's good insurance! You may even want them to mill the base a few .000 of an inch for better compression....leads to a better performance gain!
Best of luck!
Thanks guys for the replies!!
I'll wait for the manual before diving in too.
I have one extra tid-bit of information here: The rocker arm and exhaust valve on 6 are in contact through-out the cycle. Seems a bit strange to me... I would assume if it were a broken spring/bent valve, etc, the rocker arm would lift up a good amount of clearance and then "bang" down back on the valve? No? Just throwing around an idea.
So the valve seats are indeed hardened? I was wondering since the head was cast iron(?) that they had milled in valve seats or something. It makes sense that they would have inserted seats.
If it were really a valve spring, would that require removing the head?
So it looks like I may just remove the head, bring it into a shop? $300 or so would be worth it.
You'll know right away about the spring's condition once you pull the rocker assy off the head. You dont' have to remove the head in order to do that....and that shouldn't take a book.
Eight bolts will remove the rocker assy from the head and then you can diagnose the condition of the rocker assy and springs (all of them).
There is a torque setting for re-installing the R-assy...so check with your local dealer for those specs.
On the F motors, you'll find the oiler that is in the center of the head. This is a copper tube that comes up from the oil pump....you'll need to loosen it from the rear shaft. The rocker assy has 2- 1/2 length rods that the rockers are seated on. Its likely you can get away with just removing the rear one and check it out.
Post up progress as you get greasy workin on it tonite!!!!
Remember this:
Once the cam forces up on the rods.... this puches the rocker up, forcing the valve open...the only thing that will close the valve is the force of the spring.
You may be able to force- it back into the closed position once you hand-rotate the motor into the appropriate position. Throw a huge socket on the lower pulley, and rotate the motor over (ignition off!) and see if you can get it into #6 compression stroke.
I think you'll be able to hand force- it.....not hammer- force it into a closed position.
Jeff
Sweet, sounds good. I'll try and take the rear rocker shaft off and test to see whats going on!!
I'll see which way the motor turns and try turning the crank by hand, and hopefully find the compression stroke for #6.
Taking off the rocker arms won't effect adjustment I'm guessing, right? The set-screws/jam nuts won't be moved....
The top "retainers" or collars on the valve springs... Are those shims or ? Why is the #6 exhaust collar a different color/look than the rest of the valves?
If you take the rockers off the shaft, pay very careful attention on order (of the rockers) and the orientation of the shaft.
There are scalloped groves in the rocker shaft that have to line up with the vertical bolts coming out of the head. If you put the shaft in wrong -it won't fit when you try and re-install.
Have fun - it's not too hard.
There's lots of threads on Head Gaskets on this forum.
Rocky
It might just be a "stuck" valve...it happens sometimes. Maybe whack the valve stem with a mallet. See if it unsticks.
If the valve and rocker arm maintain contact all the way through it sounds like there is no clearance in the adjustment. When you get your FSM try adjusting the valve to its proper specs, then try your compression test again.
Of course, lack of valve lash may have burned the valve seat and you would have to do the head anyway.
a remedy we used was to stuff a rope down the spark plug hole and turn the engine over SLOWly; it would pop the valve up.........IF it was only stuck..........not if it was bent and then you would have to take the head off anyway.........be carefull and use braided 1/4 inch rope and secure the ends so they won't unravel.... HTH
Lou
Interesting point...
This afternoon I plan on removing the rocker assembly. I was assuming I wouldn't have to remove each arm off the shaft. Someone had mentioned to remember the orientation and placement of the arms... I'll do that if I have to disassemble everything.
When you guys say "whack it with a mallet" are you saying to whack the valve stem downwards with the rocker arm off ?
Also, the issue with the rocker arm making contact throughout the up-down cycle and never letting off makes me think its a weird adjustment issue... Like there is a mis-lengthened pushrod or lifter?!! Is that possible!?
Also, do these engines have solid lifters or hydraulic?
Do not remove each rocker arm, pull the rockers as a unit.
Pull your pushrods and check that they are all straight.
Those are solid lifters down there...
If you wanna whack that valve, hit the top of the valvestem and whack it straight down towards the cylinder. Put that piston at BDC first...
When you pull your pushrods make sure that they do not get mixed up. They need to go back in the hole they came out of. Take a cardboard box and turn it upside pown, use a knife to make 12 X slots, number them corresponding to your cylinders, as you remove pushrods put them in the correct X slot to keep them in proper order.
To check for straightness, take each pushrod and lay on a flat surface, rolling them will show you if they are bent or not.
Good Luck
You shouldn't pay anything close to $300 to have your head worked over. I just had one done. I paid $120 for magnaflux, acid dip, valve grind, valve seal instal and .006 deck. If you pay more than 200 bucks you're getting way ripped off. I didn't read through the whole thread cause I'm on my BB so maybe someone said this, but make sure you buy the M13X1.75 tap from MSC to chase the threads in the block for the head bolts. Additionally, wire brush the head bolts too.
Good luck
# 6 exhaust valve is toast, bent real bad by the picture, Might have damaged the head. I'd go for new valve guides and valves on the rebuild. Not sure about your year but my 74 head came stock with super hard valve seats, a good thing so stay stock there. Old Landcruisers are.....well lets just say if you don't look it ain't broken might be a philosophy you might want to consider adapting. For example, those rockers and rocker shaft could be worn. Easy enough to find out if you wanna go there.
Yep, unlike many heads of that era, the valve seats were hardened from the factory by Toyota
Thanks for the tips on removing the head bolts, and chasing the threads...
I decided today to wait for the FSM before diving in....
I agree, no matter what, the valve has been stuck open for "god knows how long".... 99.9% chance its toast. Might as well just take the head off and bring it to a shop. Theres nothing that I can do, that I can think of that will remedy the situation...
From the looks of it, I can remove the head bolts easily (except theres that one underneath the rocker shaft...) and take the head connected with the rocker arm assembly to a shop, correct? Will they check the rocker arm assembly? If its easy enough to tell for worn rocker parts, it doesn't look too hard to change them out. I'm hoping the FSM will guide me on how to check if the rocker parts are worth replacing.
Yah, I would be happy to see the price under $300... My buddy who brought his Jeep head in a few years back said it cost $100 for everything. That sounded low to me, but, I will be going there first. ;)
