Removing Condenser
I was removing a condenser just now without reading the service manual.
After I unbolted both the pipes from it, it started shooting out green stuff, which I'm guessing in refrigerant.
Scared the s*** out of me. Anyone who saw me from the street probably had a good chuckle.
Question: Is this stuff toxic? I got a bunch on my shirt and skin.
First off, I got a little chuckle reading this. It was a good play by play with good suspense leading up to the grand finally. So thanks for that As far as in aware, r134 is safe and non toxic. But I do suggest washing it off.
The msds sheet says may have a little irritation and to flush it
The green stuff is oil, you need to add that much back to the system or the compressor could seize
Thanks.
They dye it neon green so it looks like your typical toxic sludge.
[first post] I need to swap out the leaking condenser this weekend, and wondered if I need to pull the radiator and such? It looks like I 'might' be able to disconnect the AC hard lines and drop it down, but past experience with other vehicles (this is my first fzj80 and just sorting out all the immediate bugs) has me appreciating the knowledge of others who know where that hidden bolt lives... as well as the humorous reminder from above that I need to add pag oil after the swap. Hopefully you appreciate that I'm laughing with you and not at you Kenny, as my toxic slime is surely coming. Many thanks!
You don't need to remove your radiator. At least I didn't on my 1996.
It helps to remove the left front turn signal so you can disconnect the drier easily if you need to do so.
Also remove the grill.
And, even if you think you have all the pressure off, there is still pressure at the condenser that will help make sure you are wide awake.
Remove the grill and put all the screws in a magnetic tray.
Get some PAG oil with UV Dye so you can find a leak in future. I forget what weight PAG oil, but a quick search will provide?
I would do Accumulator/Drier (RockAuto.com Denso Brand) while I had system open.
Have the system evacuated by a shop and filled to correct amount. You will have exponentially better results, or you can save the $ and put in cans yourself and contaminate oil with air, and have mediocre results now, and certain failure in future.
PAG-46 (or ND-8). If you're going to recharge yourself you'll need a vacuum pump and manifold gauges, you can theses up for less than $200. Probably slightly cheaper to pay someone to do it but I'd rather have the tools...
Wow - this is awesome info guys. The LC I bought 4 months ago had been sitting for years... rotten hoses, rotten radiator, scary belts, etc. It is getting there, and also fascinates my wife by the 'nods' she gets from Toyota guys in grocery store parking lots and stuff. Last weekend was the first hot one in Boston so I just realized there was no AC, tracked it to a rotten lower part in the condenser, and here we are!
Assuming the o-rings, pag oil, and condenser arrive, I'll tackle this Friday night after my 2 and 3 year old are asleep.
Thanks again for sharing your experience.
A quick update that may save people money on a variety of projects...
@ FREE TOOLS -- AutoZone just loaned me a 2 cfm electric vacuum pump (I already have manifold gauges). Yes, I paid $155+ tax, but if I return it to them less than 90 days, they assured me that everything would be credited back to my account. Good or bad, I also gave them my phone number, so assuming I lose my receipt, with my phone number and the vacuum pump, they can look up the sale and credit my account that way too.
Yes, I'm still skeptical that this will all work out, but it looks promising.
Waiting for the condenser to arrive (maybe tonight) and then I'll tackle this, and get my money back at AutoZone.
It's an easy job. Can be done swapping parts faster than you can vacuum and fill.
Huh? You have to disconnect freon lines to put in the condenser.
It's like your saying you changed your socks, but never took off your shoes?
yeah, and then you need to pull a vacuum after you are done with everything. it doesnt matter if you pulled a vacuum and saved everything, once you open it up it needs to be vacuumed all over again. i typically do a vacuum, let it sit for 15 or so minutes to check for leak down and then charge it.
not sure what you are talking about with the socks analogy.
I see what you were inferring. The Changing of Parts takes more time than doing the Vac/Fill.
I did a component each night after work did the Condenser, Evap Clean and replaced Expansion Valve, then did Accumulator/Drier.
Not the easiest job, but got it done.
Someone should make a video of these processes like they did for the motor oil seals.
The compressor takes 15 minutes, the condenser is also a quick job but that expansion valve is a pain.
How do I get the drivers side (North America) headlight out? There is one bolt accessed from below that is a very tight reach, and I get about 1/100th of a turn with the crescent wrench -- it seemed to me that there must be an easier way that I'm not seeing. It feels like if I could get the corner marker light out I'd be set.
Access to the accumulator/drier through the turn signal area is ok, but working down from the top (through where the driver's headlight currently is) would be a lot better.
The corner marker light has one small screw on the top. Remove that and then pull the corner light straight out, ahead, it's held in with a bulb like stud into a female receiver. Just pull/wiggle gently after removing the screw and it will pop out. Then you can easily see the bottom fastener for the headlight.
SWEET! Thanks Tedward. I had the little screw out, but didn't pull/wiggle the result. Excited to get dirty with it again today!
I am guessing you know but also remove the little rectangular light (what's it called?) under the headlight. It has 2 small screws holding it in. This should give you room to see and work. Don't crank those headlight mounting bolts back on too tightly. The headlight mounts are plastic and can be squished/cracked. Used DS headlights are a bit more expensive so be careful. Good Luck
Hi all,
I wanted to add a brief update, as the wife and kids are happy -- the AC is blowing cold now.
As a quick rehash, after being unable to hold a vacuum, I put in some 134a and watched it spray green ooze out the bottom of the condenser. It was clearly corroded and needed replaced.
I ordered a new condenser on amazon (I'm know I know... but the 'prime' option of free fast shipping was compelling), and with the help of several above pulled everything out. For those hoping to do this, if you pull out the grill, drivers side headlight (read above on how), and remove the hood latch assembly.... you can access the 2 AC fittings and the condenser will lift right out. After a 'test sizing' in the driveway with a headlamp, I decided they were identical and moved forward. 10 mins later everything was together except the AC fittings. I worked on these for the next 2 hours, as I couldn't figure out why my fittings didn't seat into the condenser. Realizing that my o-rings were long since shot, I pulled the condenser and took a break.
Two days later (my wife uses this as her daily driver, I ride a bike to work) I attacked it again, doing a test fit of the fittings on the drivers side as the hose is longer. It didn't seat. I thought about using a file on the male fittings to resize them, but decided this was a dangerous path. Instead, I bought a new condenser from the local AutoZone (free shipping to the store). Visually, it looked identical, but the new thing was the fittings actually... fit! I quickly pulled it out again, and added in my best guess of 1.4 oz of Toyota pag oil into the condenser. This was now round 4, so I'm worlds quicker at knowing the order, and it was all bolted together in about 30 mins.
AutoZone was supposed to have 'free' rentals of their equipment, and I needed a vacuum pump to really do this. One has to 'buy' it for $156, with the expectation that it will all be refunded to you, assuming you bring it back in 90 days. With some fear as to what happens if I didn't abuse it but it broke, I 'bought' one and moved forward.
After installing a new receiver/dryer (reasonably easy after you pull the drivers side headlight), I hooked up the hoses and let the vacuum pump run for an hour. I turned off the vacuum pump and let it sit for half an hour.... still had a vacuum.
The outside temperature was about 90F on this Saturday afternoon, but I added one 12oz can of 134a, then started the LC and put the AC on high. The 1996 factory service manual I have (my LC is a 1994) said that I needed 30 +/- 1.76 oz of total 134a to fully fill the system. After about another 1.25 cans, the pressures on the gauges looked about right (charging only through the low pressure side though, 50psi on low side, 240 psi on high side) and the AC was blasting cold, so I called it good at this point.
That was a little less than a month ago, and the AC is still working great. I'm in Boston, so it isn't often hot, but coming back from New Hampshire on our first camping adventure this weekend, the cold blast kept my two little boys sleeping the entire ride home. Yesterday I took the vacuum pump back, and they returned it without question and credited my account. I also sent the condenser (via amazon) back, and they gave me a refund also.
Lessons learned -- the LC is as simple to work on as I hoped (previous off-road rig was a frankensteined 1985 CJ7), assuming I get the right parts. it also has tons of storage for road trips (2-week car-camping planned around Prince Edward Island for the end of August). Yes, I've put in about $1500 worth of parts converting it from 'parked in a garage for 3 years' to a reasonable daily driver, but I'm beginning to love it.
My boys in the car seats can also look out the windows, and even after 5 months, my wife still feels cool when she gets a simple 'thumbs up' at the park or grocery store.
The best part is having my 2 and 3 year old out there holding lights and grabbing bolts for me. It takes three times as long, as is great the entire time.
Thanks to all who helped me on my wandering way with this -- you helped to make all this happen. If you're sort of Boston local and need a hand at this same thing, just PM me and I'll be happy to lend a hand.
