Removal of HVAC Control Panel
Raton, New Mexico
ref: '85 FJ60
A scanner was installed in the ash tray slot. I need to remove that plus see why the fresh/recirculate lever won't move full stroke.
The HVAC controls, ash try and some switches are in a panel in the center of the dash.
Question: Can that panel be pulled without removing the dash cap?
Thanks
Jim
Yes.
There are a few screws that hold the panel in. And a screw or two on the roof of the ash tray. Dash stays.
Apply some light oil to the push-pull control wires that the levers move and work them back & forth. They can get sticky in their housing.
Yes.
Your knowledge is encyclopedic - many thanks.
I hope it is a sticky control cable but it might be the fresh/recirc door. When you push it towards recirculate it feels like it is compressing a spring. Let go of it and it springs back towards fresh.
could you guys give me a picture of the recirc cable where it hooks to the flap. mine suddenly stopped, like a spring fell off or something else happened.
Maybe the steel push-pull cable is binding inside its outer guide housing
Has anyone figured it out yet?
One of the previous owners has an aftermarket headunit installed with a small amp behind the dash.
I can easily set it to Fresh Air but it will not go to Recirculate, the lever will only go halfway.
Currently it is in Recirculate if I manually set it there under the dash.
