Remote Start?
No such luck on my 08. No remote starter module... bummer
I feel your pain
Is it standard on 13 LCs. If so mine doesn't work just tried it
Not a standard option. Some come with it, but it is listed on the option side of the window sticker.
I have it doubt I will ever use it. Live in Austin and if I am ever where it is really cold I don't think it's good for a vehicle to do a cold startup and then idle for an extended period of time. Plus even though no one can breakin and steal it that does not mean some idiot would not try and breakin and damage my LX thinking they could steal it.
-25F this morning. Plugged in my LX last night just to cut back on the stress of a cold start. Hit the remote start when I started getting ready for work and the truck was toasty warm when I got in. WORTH IT! :)
It's 60 degrees this morning here in Austin. Pretty sure the beast is warmer then that out in the Garage ;). Just remember if it doesn't kill you it makes you stronger ;)
Hold NO idea my LX had this until I just tried the lock twice and hold down for 3 seconds and she started right up! AWESOME!
Yup, I realize this is an old thread.
It is definitely not standard on the LCs. My '15 does not have it. But, I do have an aftermarket "CompuStar" one installed. It generally works the same, although now I have to carry 2 fobs if I want to use it. One big advantage is it has a much longer range, I can start the truck from across the street, and the remote will tell me if the engine is running.
...but it now also shuts off when I step away with the key in my pocket. Example is if I step into the store for a soda with the family still in the car, I have to leave the key with them.
This is not normal. I do this all the time, the truck shouldn't shut off.
If you have one it will say it under the hood. After you open the hood look up and if you have it it will state this vehicle is equipped with remote start. I guess techs need to know this before the work on the engine?
Yes, there should be a warning sticker under the hood somewhere, usually right next to the hood latch.
Rarely use it in San Diego. But when on vacation, I use it in extreme hot or extreme cold to pre-run the HVAC.
I've also used it when in my travel trailer when using my inverter. Starts the car and gives a nice extra boost to the batts to run the microwave or coffee maker.
san diego, does have the best weather in the us from subjective point of view.
My new-to-me '13 has it...found out when messing with the remote buttons and of course the motor shut off when I opened the door. Then I couldn't find anything in the owners manual about it and thought something was broken. Doh...great feature even if it shuts the motor down when you get in the car.
Question about the OEM remote start: I discovered the other day that when I remote start with my CompuStar system, that if I open the rear hatch (which unlocks all the doors) that the engine keeps running. But, when I open any of the entry doors, the engine quits. Wondering if the factory system does this? Just curious.
Also wondering what would happen if I crawled into the truck through the hatch, got behind the wheel and tried to drive away, even if I had the fob in my pocket. Not that it is practical, again just curious.
It's a factory toyota oversight. My 2012 Grand Cherokee has factory remote start. I start it remotely and the doors stay locked. I unlock it by the handle with my FOB in my pocket and it stays running. I can hop in but it's not shifting or moving until I touch the brake and hit the starter button. Then I can go on my merry way.
I would be interested to see if the vehicle could be operated if someone was locked in the vehicle while its started remotely. The reason I'm wondering is perhaps a savvy tech could disable the part of the process that cuts the engine when the door is opened.
Resurrecting an old thread here... It seems that Toyota disagrees. My wife's 2020 GX shuts off when you use remote start and open a door.
But now it doesn't remote start at all, because I don't feel like paying for it.
But I just discovered that my 2010 LX570 has the non-subscription based remote start system, I was pretty happy to find out that it works. Now it doesn't even bother me that it shuts off the engine when I open the door. At least I don't have to pay for the feature to work poorly!
I have the sticker under the hood in my, new to me, 2013 LC. But it doesn't start after 2 presses and 3rd hold of the lock button. Any other way to confirm if the system is still there or removed?
How does one get a build sheet? I'd be interested to know if it was dealer installed or third-party installed.
