Remote start, daytime running light question
Camas, WA USA
I am going to be getting a remote start/alarm system for the LX450. In the past I had a unit in my 93 80, it worked great, except you could accidentally/unknowingly hit the "start" button while it was in your pocket. It had a run time of 15 min and would automatically shut down. If this happened, and I came out an hour later, or the next morning, I would find the battery dead, because I always leave my headlight switch on. With the FZJ80 if your headlight switch is on, it will automatically turn off, when the vehicle is turned off AND the front door is opened (ie. you parked the car and are getting out). With the remote start, it would turn the lights on (headlight switch had been left "on"), but even when it shut the engine down after 15 min, the headlights would remain on, since there was no one around to open the front door.
How do the DRLs work? Is there a way to make it turn on with ignition on, and turn off with ignition off, in order to prevent my previous dilemma? What systems are available, or are a good buy?
Fortunately the remote start/alarm system I am getting has a "button lock" feature, where you have to hit two buttons, in order to unlock the fob, than you push the command you want, so hopefully accidental starts will be few and far between.
It would probably require a little playing with it, but it looks as if it may be as simple as supplying the door pin input to the light retainer relay and then isolating the balance of the interior lighting circuit with a diode. That way the relay would "think" that the door was always open and just turn off the lights when you turned off the key.
If that works, you could take it a step further by only supplying the relay with the "false" ground only when the remote start was active, thereby leaving the circuit functioning as it did originally when you were actually driving and shutting off the vehicle normally.
I think you could perform this test as easily as starting your rig with the door open and then shutting it off. Do the lights go off when you turn off the key? If so, I think my plan is sound:D.
That makes sense. I may give it a try, when I get my remote start system.
So I started messing with the alarm/keyless/remote start yesterday. I found the wire to ground, to make the lights turn off when the ignition is off, but I do need a diode on it, as the door/dome lights remain on all the time. What amperage diode would I need for this? I am clueless, with diodes. Looks like I will need a few 1A diodes to make the unlock feature work correctly, so I will be heading to Radioshack in the morning.
