is there a way to get the air out of the air suspension without removing or cutting the air lines? Looking to install a spacer but don’t want to mess with the lines and get any leaks.
There is a specialty tool Toyota uses that is pricey and someone on here was able to cut some tube to work like the tool.
I tried to figure it out per the description but couldn’t so I just cut the lines and tossed the bags.
Here is the thread with the DIY SST tool.
The bags don’t just drop out, you have to release the clips on top of them to get them free. And they’re generally a pain in the balls.I tried turning it off and putting it in low and then turning it off and no dice. There is still minimal air in the bags and they won’t budge. I want to avoid removing the lines but it looks like I may have to. Thanks for the links btw!
The clip is easy to remove with long needle nose pliers but I could imagine it woul be tough to put the clip back in.
Does the spacer go on the bottom of the air bags?
