I think putting her in drive and keeping it stationary while raising the RPM would put it under the load.
Yes I am concerned abt the LTFT being nearly 20% but the STFT is actually negative! Not sure what to make of this- did my fiddling with fuel injectors actually addressed the issue temporarily so the STFT are now trending towards improvement?
If yes then does that mean I should start with replacing the fuel injector seals?
No, just in drive while stationary isn't giving you a real load. You can leave the app on while you go for a drive and watch. When mine was acting up, I had to take it out on the road and really hit the gas hard before the FTs would start climbing up to 20. Just putting around at 35mph wouldn't really do it.
yeah, I meant to go on about the possibilities that fiddling with things did. Yeah, maybe the idle STFTs had been high until you accidentally bumped a vacuum tube into sealing up tighter, then the STFTs corrected themselves, but it will take some more time for the LTFTs would correct themselves.
But you said you had real stumbling issues under load, that doesn't sound like a vacuum leak type issue to me. A vacuum leak might make it run rough at idle, but it should be able to put down some power still when you ask it. You were almost certainly not getting enough fuel when you need it.
Now as for injector seals, my experience is that if those are just the teeny tiniest bit leaky, you're gonna be pouring fuel all over your engine and running it onto the ground. I know, because I just screwed them up a few times. If there's a hint of a gap, that fuel blasts out. They don't just suck a little excess air. Besides, your issue is on both banks as well, so bumping an injector on one side isn't going to fix the other.
Now one thing you could bump that might explain things is the fuel pressure regulator and its vacuum hose. Thats the innocent looking little piece at the end of the fuel rail on the passenger side. I'm not sure how it works exactly, but I believe vacuum is used to adjust the fuel pressure, and if I'm understanding it right if you're lacking vacuum there then it may fail to adjust fuel your fuel pressure. Not sure if that could result in lean or rich condition, though.
You could've bumped anything that'd help fuel flow better, but I'm doubtful on the whole bumping truly solving the issue thing. Most any associated issue would result in dumping fuel everywhere, and youd know it.
But if you want to know if its truly fixed, then just drive it hard for a little bit and see if the FTs get back down close to zero. If they do, awesome, but I'd still want to know what I did.
