rebuilding drive shaft
Stupid question. I have been meaning to replace my u joints soon. When I have the drive shafts out is there anything else that need to be done to them? Isn't each shaft two pieces with a grease fitting? Does that need to be cleaned or services?
Right now I do not have access to a shop, press or vice. Is it a bad idea to do u joints with a hammer if I use care?
i need to do this too. I read somewhere about the driveshafts need to be balanced in phase? not sure what that means. I was just planning to take my driveshafts to a local driveshaft shop and let them replace the u joints and rebalance them.
With no experience and no real knowledge of your driveline's overall condition, taking it to a reputable shop would be wise. All info pertaining to your Landcruiser can be found in the FSM.
I don't THINK it is much of a problem when using OEM joints, but with most after market parts, it gets tricky using the right thickness of C clips to lock in the bearing caps. They should be brought inboard ALMOST to touching the ends of the cross, but not quite. And, both caps need to be brought in exactly the same amount or the cross will be off center and create balance issues. BTDT.
It can be done with a hammer and some sockets (AND a bench vice!!! Something that can grip the piss out of the caps is needed to pull them the last 1/8 inch where the cross jams up and cant be driven any further) but as someone that has, a few times, take my advice. Don't. Find someone with a shop press. You'll need to fabricate a small u-shaped bracket to push on the perpendicular cross vs the highest point, but it is MUCH easier and far less likely to mess up the very close tolerances of the driveshaft ends.
To do a full rebuild you should mark the shaft so it can be put together indexed correctly, then take it apart and clean out as much of the splines as possible. There is a dust seal that blocks full access to the male side of it.. but I've always been able to get the job done well enough and leave it in place.
If you do make sure they use OEM joints. Aftermarket are not as strong, and as someone else mentioned aren't sized as closely so if the shop doesn't have the correct assortment of c-clip shims, knowledge, and experience... it won't be set up correctly. They'll slap it together, balance it as is, and as soon as you install and shift something it'll be out of balance again. These shafts don't often get rebuilt by drive line shops so they don't get much experience.
In phase just means if you look down the length of the shaft the ears will be lined up perfectly.
Thanks guys. Maybe I will just wait till I get home. Pull them and see if ACC will take care of it.
Just a question. Why do you feel the U-Joints need to be replaced? Is there too much play in them? If there isn't any problems - just lube them at the zirk fittings, clean the drive shaft, lube it - and call it a day.
If it ain't broke - grease it!
JMO
