The first project on my 1978 FJ40 that I'm going to work on is rebuilding my transfer case. It started whining on the drive home on Saturday after buying the FJ40 (this is my first Landcruiser). When I pulled over and looked there was oil all over the underside of my rig, and the transfer case was really hot! I don't think it seized, but some bearings or something in there are probably shot. Of course, I'm not a mechanic so I really don't know what I'm doing. I ordered the Factory Service Manuals a few days ago, so they're on their way here.
So, any advice on how to proceed with this project? Here are the questions that come to mind:
If you've done one of these, how did it go and what should I be aware of?
What would you do differently if you had to do this again?
What rebuild kit (if any) would you recommend?
The only tools I own are a small socket set and some wrenches (I'll obviously be buying tools). I'll need a workbench, better lighting, jackstands, a hydraulic jack, etc. What else should I get to make this (and future) jobs easier? Keep in mind that I only have a two car garage. I can pull the car out of the second bay while I work on this, but they both have to fit when everything is put back together!
Since I'll have to pull the tranny and gas tank (according to the Haynes manual) what else should I work on in conjunction with rebuilding the transfer case (clutch comes to mind)?
I'm eventually going to do a frame-off restoration, but for now I just want to go through and make sure the mechanical and electrical systems are reliable, get it back on the road, and drive it!
Thoughts?
Thoughts?
