Yes, that’s a hunk of wood that the glass is resting on. I found the piece the window should go on at the bottom of the door, and the motor brings the arm up and down.
What am I missing?
I just fixed my rear windows. My fronts were held about 2" open by one wood screw per side, which the glass rested on. The rears were propped mostly shut by wooden dowels!
There should be a rubber U shaped molding that goes into the metal channel, then you press the glass into the rubber molding.
The 94 FSM says to lubricate the channel with soap and then use a plastic hammer to whack the channel and molding into the window glass.
The first mistake I made was using silicon grease. I got the window partly seated, but as soon as I tried to lower the window, the glass popped right out of the channel! You want to use something like soap that will lubricate for the insertion, but dry out and help the glass stay firmly in place. I used RU-Glyde, which is a tire mounting lubricant I happen to have. *Maybe* WD-40 or hairspray (tricks used to get dirt bike grips mounted) would work.
You'll want to lower the window regulator enough to slip the wheel into the track before pressing the glass into the channel. Once you have the glass pressed in, you can push the bracket left and right using a pry bar against a block of wood, up against the door skin. If you skip the block of wood, you'll deform the door skin.
After I got mine pressed in and moved to where I wanted it (I ran the window up and down several times to make sure it wasn't going to run the wheel off the end), I used some c-channel pliers to slightly crimp the u-channel near the top lip. I wanted to make sure the glass didn't pop back out of the channel after I seal the doors back up.
Nope, that's the window frame run channel. The ones I'm looking of are inside the door. They're positioned on steel channels on the forward and trailing edges of the door.Front Door: Run Channel (listed under "Glass")
68151-60010 Left
68141-60010 Right
Rear Door:
68152-60011 Left
68142-60011 Right
I'll post photos.
Well then, that's a horse of a different color. Why didn't you say so?Door run channels are a squared U shape and go all the way from the top of the window opening to the bottom of the metal channel inside the door.
I'm working on it. Not that it'll help you nowSo I have this exact same issue going on. I believe the tracked moved because of dirty rubber window runs too. Is there a write up anywhere on how to tackle this? I have been searching but can't find a good one
That sounds entirely correct.IMO the diagram is misleading. They extend further than the diagram seems to indicate, but they don't go as far down as I've seen on some other vehicles.
I doubt you'd ever find a multi-piece run channel seal since it would be too easy for it to slip and fall out or cause binding. Every run channel I've seen is a pretty easy press-in fit, even when new.
I think the guide channel is just the metal piece, which probably never needs replacement.
I see this is an oldish thread, and I deeply appreciate the discussion on mounting the rear door glass. Im attempting to repair a rear door window issue on my 1993 FZJ80. The window Im working on had a rotten rubber filler that fit into the glass channel and I am trying to fit the window and the replacement rubber filler into the glass channel and I'm making zero head way. Ive soaped up the rubber and attempted to put the glass back into the glass channel, but I cannot for the life of me get the edge of the glass to enter the rubber. Ive tried tapping things in, but I am nervous about using too much force. So specifically:
1. How much force was required to seat the glass into the channel and filler
2. Did you have the Glass channel connected to the regulator arm before seating or did you guide the "green roller thingy" into the glass channel after you seated the glass channel?
Thanks Team!
