- Joined
- Sep 13, 2007
- Threads
- 10
- Messages
- 37
i have a 75 fj55 which in currently restoring. does the tail gate only open, when the glass is all the way down? any access from the inside to open it? tnx
or three. Spent most of last Saturday dealing with the same situation. Got it out, cleaned all connections, reinstalled motor, cleaned and regreased gears and the reward was a fast, quick working tailglate glass, including the supposedly "shot" motor. Did replace the fiberboard wiring block that connects the harness, keyed switch and motor in the tailgate. Mine was breaking in two at the block for the main power wire, as were the two in my other spare tailgates. NAPA has an appropriately sized for heavier wire plastic block, slightly shorter but another hole drilled in the mounting bracket took care of that. NAPA part # is JB3081...about eight bucks. If your tailgate is in disrepair do yourself a favor and replace the drive gear while you are in there and lub everything up. They can be bought new from Toyota for about 25 dollars.
