Rear T-Case Seal
Covington GA
So, I think that my rear seal on my t-case is leaking (73 stock fj40). I filled it up and it slowly dripped on my garage from the e-brake housing. When I took it apart today, more came out after I pulled the e-brake housing off of the t-case. I saw the part at SOR (the seal) for $7, but am wondering if i have to take the case apart to get the seal out. I just have the Haynes manual (i know, I should get the factory service manual), and it shows that you have to take the speedo cable out and the cover off to get the seal out. Can I get it out and install the new one by just taking the e-brake brackets off? Also, any special instructions on the replacement? btw, this is up on pirate to.
In order to get the seal out to replace it you will have the also remove the backing plate.
More than likely replacing the seal will not fix the problem. The drum portion of the brake that rides around the seal usually gets a grove in it. Only way to fix that is either get a new drum...highly doubtful, or get a speedi sleeve to repair the groved area. Then you can use a new seal.
You can find all the Speedi-Sleeves, bearings and seals offered by SKF for Landcruisers by entering your info on this web page.
SKF Catalog
