Rear Passenger Window Fallen Down
Tucson, AZ
My daughter was messing with the rear window when it stopped working. It kept sliding down and now it's all the way down in the door. I hear the motor but the window won't come up and if I try and lift it up, it just slides back down. The tracks seem to be in pretty good shape (I just got the TLC).
Does this sound like it might be a broken gear in the motor? Or could it be another problem? I have the panel off but am doing some research before I take off the vapor barrier.
Thanks,
Chad
It probably pulled out of the track or the wheel that rides in the rail came out. If the window came out of the track it's easiest to pull the window out and put the track back on outside of the vehicle.
Is there a tutorial that shows how to do that?
Thanks,
Chad
I have had good luck pulling the door card off, cleaning the bottom of the window off and pushing it back in the track carrier in place. One person pushing up on the track another down on the window.
Thanks. I have the panel off already. I was wondering how to do what FJP971 suggested. I'm going to try your way first though.
Chad
Get some FIPG first and apply that to the rubber sleeve that goes in the track. It'll keep it from happening again. I've had three of my four windows come out of the track fixture, sometimes a recurring problem until FIPG intervened.
It's messy, but after clean up, it will not likely happen again.
I put the arm back in the channel and when I roll the window up and down I see that the roller sticks about half way out of channel at it's farthest spot. I'm guessing the assembly wasn't put on the window correctly. What's the best way to fix this?
Thanks.
Chad
You read my mind. I just went out and took a couple photos. The first photo is the roller coming out of the channel. It is this way about half of the window's journey up and down. When I was rolling down the window it popped out of the channel again.
The second photo is part of the assembly that attaches the channel from the first photo to the window. It looks like it should be over to the right about a half an inch.
Chad
My question is how do I move the metal piece on the bottom of the window over to the right?
Chad
FIPG is great idea. Move it left or right until wheel does not fall out. Maybe 1/2 extra.
I just had to man handle it. I was afraid that I'd torque it and break the window but I grabbed the metal part and slid it to the right and now the roller isn't falling out any more.
Thanks all for the assistance.
Chad
My theory is that the window channel (rubber) needs some lube, or cleaning. I "think" when the window rolls up and down, that it puts some torque on the track and over time, slides it enough that the roller can come out. I've probably put my track back on the window glass, or put the roller back in the track near 30 times. I can do it in about 3 minutes now :doh:. That's why I FIPG'd them.
Next time I'll FIPG it. It's back together now. Hopefully from now on when I tell my daughter not to roll the window up and down nonstop because the car is old she'll listen to me (at least for a little while).
Chad
Yes, but how do I move it?
Chad
You may have already solved your issue but I was able to gently leverage my bottom metal channel back to a position where the wheel was still in the track. I used a short length of 2"x4" lumber as a pry bar at the front of the door. By gently applying pressure at the front of the channel, it slowly slid to the rear of the door until back in proper place.
A year later with kids controlling the back windows and it has worked fine.
I had the same issue last month. It was the second time for that window so in addition to re-installing the window I pulled the window runs, cleaned them, and used Gummi Pflege Stift* on them in an attempt to restore them a little. Hopefully that helps. If not I will try the FIPG next time.
*Was recommended in another thread for restoring window runs and other rubber items. Thanks to everyone who recommended it!
I may have mine at 9.23" instead of 9.15". Is that going to be a problem? ;)
Seriously though, I wonder how much difference that distance makes as long as the wheel doesn't come out of the track? Will that change the balance/leverage enough for this to cause problems faster? I can't imagine it will and I certainly can't imagine anyone actually centering this to the nearest 0.4 mm. That is way outside the tolerances of a "plastic hammer" tap.
I ran mine up and down a couple times to see how far the wheel traveled and basically just centered it by eye. If I need to get into it again in the future I may measure it to see what it is vs what they say.
