Rear Heater question not hot
Is it normal that my rear heater does not blow as hot as my front? If not, what should I do...it does not run off the same heater core as the front, right?
C
C
You could try to flush the core. That little ring is the rear heater core. You'll have to figure out where the coolant lines run and isolate the rear.
Mine is hot as hell, not that anyone ever cared yet. It kinda sucks you can't isolate it and just run the front heater. I always find that cargo is attracted to it.
I wish I had a picture of what mine looks like with a new factory-color rattle-can paint job. :)
Look for possible PO installed shut off valves that may be closed or partially open also. You will lose some heat in the longer lines but not enough to degrade the heat output as much as you seem to be indicating.
C
When my 1970 FJ40 was new the rear never blew as hot as the front. They seem to get hot but the rear fans just don't move as much air. I took my rear out last summer because it was always in the way. I haven't missed it so far, and it's pretty cold here.
