Rear Heater line replacement
JDNs78FJ40
Draper Utah
When I bought my 1978 40 the PO removed the brass lines that run to the rear heater😡 and replaced them with Gates red stripe hoses and hose clamps. I’m sure there was a good reason for this. Looking for an affordable and safe way to run the lines to the rear heater. Is the gates hose a safe alternative? Has anyone else done this. Thanks in advance.
gates red stripe?
If it's a heater hose I don't see why it wouldn't work.
I consider the replacement of the brass pipes with a quality heater hose to be an upgrade. I kept the brass "t" pipes that penetrate the firewall, but replaced the pipes that run to the rear heater with Gates hoses. This eliminates the need for the foam insulation which is a PITA to take on and off. This eliminates four unnecessary joints in the passenger compartment, reducing the chances for a leak. Periodic inspection of the hose is easy (nearly impossible with the brass pipes if you still have the insulation on them). Unaffected by corrosion and the occasional hit, kick, or ding (brass pipes are really easy to dent). City Racer, a highly respected vendor in these parts, is even working on a silicone replacement version which is molded to fit the bends of the brass pipes, for all the reasons I have stated. I couldn't wait, so I just used Gates hoses with much success.
Thanks for the input. This is what I’m going to do.
Did you insulate the brass tubes that pass through the firewall? I had mine zinced and pretty sure they were originally insulated.
I used heater hose with no issues.
Yes the brass will need to be insulated. I had enough good original insulation to keep them insulated with the old stuff. It's working well. If you don't have any original insulation, do a search on this topic. There is a McMaster Carr insulation that folks have used with success to replace the OEM. Nothing at local hardware stores will suffice for this. Needs to be heat resistant to withstand the coolant temps.
I used Gates hoses bought at a Marine drydock in Maine 20 years ago while visitin an old Coast Guard brother that has fished for lobsters for 40 years since we got out. He swears by the name and I can back that up.
When I started my frame off 5 years ago the red gates hoses were just like new. No build up inside, and the exterior was dirty but sound and pliable.
I also used gates lines on both of my semi trucks for 20 years. Never had a problem with heater hose.
My brass "t" pipes at the firewall look a little different than @Advrider639's. My brass section extends all the way to the heater core inlet and outlet, so I connected a short section of heater hose, OEM style, to the inlet/outlet with 2 clamps on each. That is why I needed to insulate just that part of the brass. If your setup looks like @Advrider639 , then no insulation is necessary in my opinion. You're good either way.
I've had rubber hoses on my rear heater for over 20 years. Overheated a few times and never had any issues. If you have enough pressure to burst the hoses, I think you have a bigger problem lurking inside the engine.
