Rear Heat- solid line replacement
Southern Maine
I have a 1997 Limited 40 Anniversary with a rear heater hose that is starting to leak. I did some research and wanted to confirm these part numbers are correct.
87248 and 87248Y. Are they even still available?
The lines are located at the rear of the engine bay on the firewall and go down along the transmission and and then connect to the rubber hose that connects to the heater unit located under the passenger seat.
As always, thanks for the assistance.
Thanks
So for the left hand side you ran a hose from the black pipe (that normally connects to the firwall pipes) and just draped the bulk hose behind the head or over the bellhousing/transmission? Hard to make out which.
Over the bell housing then over to/above the frame. Runs mostly above the frame to the rear heater. I didn’t put much more thought into it than “stuff it down here and keep it away from moving parts”. Many zip ties holding the hose in place to various “things”
