Rear end swap
I am putting in a np405 transfer case I need to find a rear end that has a center diff the one I have is offset to the right
The rear ends from 1979-85 Toyota mini trucks are the same width as your stock FJ40. They are centered like you’re looking for.
And they will have the parking brake at the rear drums. Be sure to get all the parts.
Welcome to the site.
If you have a 79-85 mini truck rear end and have some skills you can make a L/C/minitruck hybrid centered rear end. It allows you to retain the L/C 3rd member with the 9 1/2" ring gear, eliminate the axle C clips, and use the mini trucks drum brakes. It's not that difficult, and you can sell the mini trucks small 3rd member to recover the cost of the mini's axle. I bought a mini truck axle for a $100 and sold the 3rd for $100. I found 1 that had 4.11, so it was very desirable. Gear ratios are designated by paint color on or near the pinion flange on mini truck rearends. I believe pink was for 4.11:1
I did the hybrid it came out great Thanks for all the information
